Hi guys,
I have a 5 year old Samsung PC monitor that does not do anything when powered up. No power LED, no LCD backlight, nothing at all. I have taken out the power board and all the caps seem to be alright. I have heard that caps can be bad even when they look visually OK. I want to know is there any way that I can test the caps in-circuit with a cheap DMM? I suspect two 820 micro Farads caps on the baord.
I also want you to know that the monitor had gone bad earlier also but miraculously, disassembling and reassembling it did the trick. I suspect the logic board also and know that replacing it is next to impossible. Any way of checking the power board caps would be very helpful.
Thanks.
Thanks.
