Sanyo DS25330
F
Frogg
We have two Sanyos. One is DS25430 and one is DS25330. Under the menu,
option appears to setup the channel list. Both tvs show a list of 0 thru
129. The DS25430 picks all channels available through our cable company (
2 thru 99). The DS25330 stops at channel 47. It shows that it is
checking channels from 0 thru 129, but will not select anything beyond 47.
Manually selecting does not help. All higher channels show a 'bleeding'
version of a much lower channel.
Cable company representative has been here to check the wires and
connectors. He found no problems.
Is there something that we can do to the tv to get the higher channels?
Thanks.
dkuhajda
UHF band in the tuner in the DS25330 is not working. An experienced
technician might be able to find some failed solder connections inside the
tuner, or the whole tuner needs replaced.
David
F
Frogg
Thanks for that suggestion, David. Will try and get someone to check it
for us.
Gina
