Selecting Mosfets for Lowest Power Dissipation
D from BC
I'm currently trying to find an effective way to select a mosfet with
the lowest power dissipation for the following circuit values:
Id=2A
Vd=270V
f=100khz
D=40%
Mosfet Driver Specs
Claims up to 2A peak gate drive
Tf = Tf = 14nS with 1nF load
Rdson is just a conduction loss.
Gate capacitance is the main cause of switching loss due to slowing
down driver rates. <<Not sure about that..
Rdson and gate capacitance are inversely proportional for mosfets?
<<Not sure about that too..
If so...
By finding the balance between Rdson and gate capacitance, I could get
less total power dissipation.
In that case...
Is there a figure of merit...Maybe like Ciss/Rdson? I just go for the
smallest number?
I've been looking at the SPP21N50
Rds(on) 0.19 ohms
Ciss = 2400pF
This mosfet has a great Rdson but I wonder if I could get less
dissipation with more Rdson and less Ciss?
What's a good selection procedure?
I''m hoping for some hints while I google for answers.
D from BC
D from BC
I found this:
Taken from
http://www.maxim-ic.com/appnotes.cfm/appnote_number/1832
"Once you have narrowed the choice to a specific generation of MOSFET
based on cost (the cost of a MOSFET is very much a function of the
specific generation to which it belongs), select the device within the
generation that will minimize power dissipation. This is the device
with equal resistive and switching losses. Using a smaller (faster)
MOSFET increases resistive losses more than it decreases switching
losses; a larger (low RDS(ON)) device increases switching losses more
than it decreases resistive losses."
Neat.....50 50 on the losses...
Rough formula for switching loss:.
Pdswitching = (Crss x Vin^2 x fsw x Iload) / Igate
(Igate is the MOSFET gate-driver's sink/source current at the MOSFET's
turn-on threshold (the Vgs of the gate-charge curve's flat portion).)
How much does Crss vary among mosfets?
What a PITA...I also have to estimate Igate..
Once I solve for Pd then I can calculate the corresponding Rdson..
Then I have 2 specs to pick a mosfet out of a table of mosfets.
Am I on the right track?
Shortcuts??
Is there an app where I just fill in the blanks and it just spits out
a part number? :)
D from BC
H
Henry Kiefer
Sounds not so bad. Generally spoken, newer devices have lower losses (=smaller chip inside).
I use LTspice to run efficiency calcs. It's easy. Use digikey to find what is buyable.
I don't understand how Mot comes to the 50:50 rule.
- Henry
www.ehydra.dyndns.info
| I found this:
| Taken from
| Shortcuts??
| a part number? :)
| D from BC
John Fields
Id=2A
Vd=270V
f=100khz
D=40%
Mosfet Driver Specs
If so...
In that case...
smallest number?
Rds(on) 0.19 ohms
Ciss = 2400pF
Rds(on) and Ciss aren't related except that the longer it takes to
charge and discharge the gate capacitance the longer it will take to
turn the MOSFET on and off. That means that during the time the
channel is in transition it'll be dissipating a lot more power than
it will be for the same time when it's either on or off.
Ciss doesn't dissipate any power in the MOSFET except in the ESR of
the gate capacitance, but the driver has to source and sink the
charge and discharge current, so there will be some power dissipated
in the driver.
So, what you want to do is get a MOSFET with the Rds(on) you
need/can afford and the lowest Ciss you can find, then drive the
gate as hard as you can so that the MOSFET will turn on and off
quickly.
Using a MOSFET driver will save you a lot of woe, and some good ones
are at:
http://www.micrel.com/page.do?page=product-info/mosfets.shtml
D from BC
in the driver.
quickly.
are at:
You mean do it like this?...
Let's say I can waste 2watts...
Then I solve for Rds(on).
Then I look at all the mosfets with that Rds(on) and pick the one with
the lowest gate charge.
Then ram the gate with powerful mos drivers and hope that Vg can rise
and fall fast enough to lower switching losses. (Slow operation =
heat.)
Hopefully the switching loss is not significant compared to the heat
from Rds(on).
What I'm looking into is:
Given Id, Vd, Igate, freq, duty; does a power dissipation minima exist
given a wide assortment of mosfet Rds(on) and gate charges? A sweet
spot...
D from BC
D from BC
- Henry
I know...The rule is strange..
50% heat due to switching and 50% of heat due to Rds(on).
It shouldn't matter what combo...2%, 98%....40% 60%...20%80%....
I just want lowest mosfet heat. (Neglecting mosfet driver dissipation)
I could create a table of Rds(on) and gate capacitances based on
mosfets available at digikey.. Then run multiple simulations in
LTspice to find the coolest mosfet..
Something just seems wrong about this...
D from BC
H
Henry Kiefer
| On Sun, 11 Feb 2007 12:20:12 +0100, "Henry Kiefer"
| >- Henry
At least the rule must have a function of duty-cycle!
- Henry
D from BC
I recently found this at:
http://pd.pennnet.com/display_artic...Switching-loss-in-switch-mode-power-supplies/
"It's surprising to note that at higher switching frequencies, a
MOSFET with higher on-resistance can actually improve SMPS efficiency.
You must look beyond on-resistance to understand this behavior. "
So...I'm thinking..
Given a mosfet drivers trise and tfall, I just have to get a grasp on
how to pick a mosfets Rdson and gate charge.
D from BC
John Fields
On Sun, 11 Feb 2007 08:52:50 -0600, John Fields
Where?
In the MOSFET?
In the driver?
Total from the supply?
OK, that'll get you the steady-state dissipation if you know the
supply voltage and the current into the load.
Yup.
heat.)
That's the trick!
The faster you can turn that booger on and off the lower your
switching losses will be, but you'll have to pay the piper in the
driver.
spot...
Sure, and there's nothing magic about finding it.
If what you're concerned about is steady-state power dissipation in
the MOSFET, get one with the lowest Rds(on) you can find.
If what you're concerned about is switching losses, get the one with
the smallest gate capacitance you can find and drive it with a
voltage source.
If what you want to do is to get the best of both worlds, then
you'll have to do the legwork to find out who minimizes both WRT
your application.
D from BC
I've heard of SiC Mosfets with ridiculously low Rds(on) but I suspect
it's not available yet..
D from BC
D from BC
Where?
In the MOSFET?
In the driver?
That's the trick!
driver.
voltage source.
your application.
Ooops... should have specified that 2watts wasteable ..in my example..
That would be 2watts = drain|source dynamic heat + heat from Rdson.
I'm assuming that mosfet heat is far from the driver heat and is
negligible.
(D=40%, f=100khz)
I don't know yet if the legwork is worth doing.
... For all I know I could spend hours just to discover the math and
compare dozens of mosfets to get that optimum Rdson/gate charge combo
and only end up with a minor 10% improvement compared to just
selecting the lowest tolerable Rdson.
D from BC
john jardine
heat.)
from Rds(on).
spot...
D from BC
I've never hit a sweet spot. I filter on voltage it can cope with, then
current, then price, then buy a couple.
10nF, 1nF who cares? those gate C's are really big. Bang 'em with gate
driver chips. Only killer is operating frequency.
God know why but I spent 2 hours last month with paper and calculator
looking at switch losses on a design using a pair of 80A FETs. Bought the
FETs and the calculated heatsink, built it, run fine. Within 5 minutes and
for other reasons I'd changed the design to a higher Frequency and a
different switching arrangement. Those 2 hours now lost for all time. Lesson
learned was don't waste valuable time with the sums, just select on price
and keep an eye on the spice.
D from BC
Interesting...
Are you saying that it's so complicated that hit and miss
determination is the faster method. Just pick the essential mosfet
specs and then compare in spice..
Select on price...Eye on spice
Nice electronic poetry... :)
D from BC
Gibbo
D said:
Interesting...
D from BC
If you look at the Rds losses and the gate capacitance losses you'll
realise you can calculate the whole lot dead easily. Then as you're
doing that you'll realise it depends not only on the frequency but also
upon the "on time" of the fet. So you can calculate the losses only as
long as you know the average on time. eg on time = 100% = no gate
capacitance losses and Rds is dominant. On time = 1% and Rds becomes
almost irrelevant and the switching losses dominate.
The Mot rule of Rds losses = to G cap losses works quite well when the
the average on time is 50%. But it's only a rule of thumb to give you a
starting point.
D from BC
starting point.
Yep...I got my eye on the duty...
For a given mosfet driver, it seems like this:
For low duty, then pick low gate charge to reduce Vds transient time.
For high duty, then pick low Rdson to make an efficient switch.
I just want to clarify that Mot rule.. (Also..what is Mot? Motorola?)
Is it...
Rds pwr = Drain/Source transient switching pwr (or on/off state change
power)
Or
Rds pwr = Drain/Source transient pwr + gate drive power required
D from BC
Gibbo
Correct.
Yes. Just an abbreviation I used which I think appeared earlier in the
thread.
Is it...
power)
Yes. But the losses increase depending how well the driver operates
obviously due to drain/gate capacitance. So both are related.
Or
D from BC
No that is added in separately.
I've read some of your posts so I know you're not daft.
Imagine trying to switch on a mosfet with a 1M source impedance. The
falling drain voltage would (due to drain/gate cap) hold the gate low
for [comparatively] ages thus increasing the switching losses (negative
feedback). Effectivley the gate drive would be slow so the drain voltage
would fall slowly (thus increasing normal mosfet losses). But you
already know this.
I imagine gnome knows all the formulae. Try a new thread with smps in
the title :)
Terry Given
Correct.
thread.
Is it... Rds pwr = Drain/Source transient switching pwr (or on/off
state change
power)
Or Rds pwr = Drain/Source transient pwr + gate drive power required
D from BC
already know this.
the title :)
dont forget when comparing FET Rdson to pick some Tj other than 25C.
different FETs have different Rdson-vs-Tk curves. I always normalise to
125C and go from there.
Cheers
Terry
Gibbo
Terry said:
Gibbo said:
D said:
D from BC wrote:
On Sun, 11 Feb 2007 23:32:38 -0000, "john jardine"
then
gate
Bought the
minutes and
time. Lesson
on price
Interesting... Are you saying that it's so complicated that hit and
miss
D from BC
also upon the "on time" of the fet. So you can calculate the losses
only as long as you know the average on time. eg on time = 100% = no
gate capacitance losses and Rds is dominant. On time = 1% and Rds
becomes almost irrelevant and the switching losses dominate.
the the average on time is 50%. But it's only a rule of thumb to
give you a starting point.
Correct.
thread.
state change
power)
D from BC
(negative feedback). Effectivley the gate drive would be slow so the
drain voltage would fall slowly (thus increasing normal mosfet
losses). But you already know this.
the title :)
Damned fine point with mosfets.
Interesting...
D from BC
(I'd missed that. Maybe before sending, I should read the stuff :).
Yes, let spice do the grunt work as your servant, while you figure the
overall strategies. It's not that the FET usage is complicated, it's
more that's it can be tantalisingly easy to sit down and spend time
doing a complete 'carved in Granite' electrical/mechanical FET design
on paper, building it and then finding real world 'minor' factors
need taking care of that could only have turned up in some long winded
tolerancing episode. E.g fitting some readily available value for a
clock cap' moves the FETs and (say) switching inductors into
occasional discontinuous cycles.
john
Gibbo
john
John I'm still trying to work out how to contact you by email. Have you
done a seacrh on jjdesigns? Quite amusing really.
