K
Klaus Kragelund
- Jan 1, 1970
- 0
Hi
I'm working on a water sensor (simply detect water or no water). The
dielectric constant of water is about 80. But what about the value of
the constant with different pureties of the water (salt, pH)?
The application is a pump which has a metallic surface connected to the
earth wire. The sensor consists of a metal plate housed in a plastic
enclousure mounted on the chassis of the pump. The capacitance measured
is the one from the metal plate to the chassis - growing in value when
the water is present.
Right now it looks to be a capacitive sensor design. But I also might
opt for a conductivity measurement of the water instead. Any comments
and experience in this field?
Regards
Klaus
Regards
Klaus
