Sentrysafe
Foxtrot4916
Feb 24, 2023
3
Hello, I would post the model ID but for the life of me I do not see it anywhere on it.
Anyhow, the connection between the pcb and the keypad broke and Im having difficulty finding the specific connector for it. Curious if you guys could help me out. The wire itself was 26awg.
empty socket partly obscured.
Did you check the photo before uploading to see if it was clear and showed what you wanted....probably a good idea.
Anyhow, appears to be 4 pin.
However, important bit is ....................you will need to measure the pin pitch ................and the type is as you say, JST.
Foxtrot4916
Feb 24, 2023
3
Here is a clear image of the pin connector Im talking about. Im starting to think I need the 1.5mm since the last wires were 2mm.
