Sequencing timer circuit
tunelowplayhard
Mar 2, 2011
Working on a concept and was wondering if I could get some assistance to build a solid state, sequencing adjustable timer circuit to control some solenoids. Here is the sequence, triggered by a momentary push button:
X=solenoid #1, Y =solenoid #2, Z = solenoid #3
X open
Y open
X close
Y close
Z open
Z close
The sequencing of X and Y is the interesting part, whereas X and Y should open at the same time, but Y needs to close (~) seconds after X closes.
Solenoids in question would be 12V, NC, not to exceed 1A coil loads.
I would prefer that timing adjustments be made by a pot.
Do you mean solenoids or relays?
Ah.
There are a multiplicity of ways to do this.
One straightforward, but possibly complex way is, for each device, have a pair of monostables. The first provides the delay between the initial signal and actuation, and the second provides the actuation time.
For relatively short durations you could use 6 x 555's.
The 555 would have to drive the devices via a transistor (or mosfet) as a 555 would not be able to supply the required current. Also you need a diode to prevent the inductive kick from destroying your transistor. (this also assumes they require 12V DC).
A simpler circuit could use a PIC and all you would require would be a single 8 pin pic, a couple of transistors, and the skill to program it. It may be more difficult to adjust the delay times outside of code though -- although it could be done.
