Hi all, I really could use your expert opinion with this one.
This PCB multi-layered its from an air-card (mobile hotspot) and the sim slot became damaged and it needed replacing. As you can see from the image attached two solder pads where accidentally detached during removal of the SIM card slot. So I need your expert opinion on this case. 1st) is this repairable...? 2nd) What's your suggestion on technique\method would be used to find and rebuild these pads....?
Thanks for your suggestions, look forward to you ideas.
