servo control via lpt problems
Mitch__
Hi all
i am working on a small project in VB, Controlling Servos by voice.
everything is working great except for one thing.
If i use one power adapter to control more than 1 servo, then
following happens
While 1 servo moves , second servo seems to get enough of a voltage
fluctuation that it will move one way or the other.
so
currently for this to work for me, i need to have a separate power
supply for each servo, then
everything works great.
What do i need to make this work from one power supply?
TIA
Mike
Mike
Try larger power supply (more current).
Without the schematics i is difficult to say if controlling one servo will
affect the other one.
Filter between the feeds to the two servos will also help, if its a PWM
servo then even with one power supply with enough current, the Power supply's
inherent output impedance may be too high for the servo's instantaneous
draw, you might need to size a supply that has a continuous rating that is
equal to the max instantaneous draw of *both* servos. If you are not sure than
add lots of capacitors and maybe separate leg inductors and capacitors
right next to the bridge driver for each servo...
Regards
Mike
* VK/VL Commodore FuseRails that wont warp or melt with fuse failure indication
and now with auto 10-15 min timer for engine illumination option.
* VN, VP, VR Models with relay holder in progress.
* Twin Tyres to suit most sedans, trikes and motorcycle sidecars
http://niche.iinet.net.au
Phil Allison
"Mitch
following happens
so
** Any decent, regulated, 5 volt PSU with a few amps capacity.
Not the puny unregulated ones you have.
........ Phil
