Servo Lock is jumping on older receiver??
I've got an Optronic (Sharp) SA-5905 and FM stations can't be locked
in... The servo lock light blinks and the signal cuts in and out... Any
ideas?
Basically, if it's old, adjust the detector coil. Coils drift.
If it doesn't use ceramic filters, that is there are interstage IF
coils or transformers, make SURE you only adjust the detector coil. It
takes too long to explain how to do a proper IF alignment on an FM
reciever. If you can't identify the right coil don't do it.
JURB
