Sharp Microwave R-1471
Paul
Our Sharo R-1471 over-the-range microwave (about 10 years old) quit working.
The interior light and fan stay on continuously, and there is no response to
most of the front panel buttons. The Sharp web site had no indication that
parts/manuals were available directly from them. Is it possible to get a
service manual, or at least a schematic for this unit? How about parts
availability? I took the control panel out and found no obvious damage.
Tracing back from the 2 larger relays on the bottom edge of the board, it
seems that Q27 is open. Marking on the part is "A223" Does that stand for
2SA223, or is it a house number?
Paul
H
Homer J Simpson
working. The interior light and fan stay on continuously, and there is no
response to most of the front panel buttons. The Sharp web site had no
indication that parts/manuals were available directly from them. Is it
possible to get a service manual, or at least a schematic for this unit?
How about parts availability? I took the control panel out and found no
obvious damage. Tracing back from the 2 larger relays on the bottom edge
of the board, it seems that Q27 is open. Marking on the part is "A223"
Does that stand for 2SA223, or is it a house number?
Someone slam the door?
Paul
My first suspicion would be the interlock mechanism. You can check the
interlock switches with a multimeter.
Probably is 2SA223, the 2S is routinely left off.
NT
Paul
NT
It appears that both of you are correct. The clip holding the upper door
switch is broken. I never would have guessed that an interlock switch would
have caused the symptoms that I was having. Apparently this particular
switch turns on the interior lamp and disables the touchpads when the door
is open.
Thanks for the help.
Paul
BTW, according to Tritronics, the full P/N for Q27 is VSKRA223M//-3.
SAL
Nov 29, 2009
I have the same Sharp model R-1471microwave and it had the same symptoms. It had been unplugged for a few years now because I have another microwave, and to replace the R-1471 with a similar model (1.0 cubic foot) would have cost $400+. For some reason, microwaves in this smaller size are expensive. While I can get a 1.5 cubic foot over-the-range microwave for under $200, I would have to do a little carpentry work on the cabinets and it would stick out 1.5+ inches further. I checked the switches as mentioned above and, sure enough, the top door switch was not attached very well so it would move when the door lever hit it. Apparently, the tab behind the switch that prevents it from moving had broken. The bracket has another position that it can be mounted (higher up and upside down) so I popped it in upside-down and just had to replace the grounding wire on the switch with a longer one so it would reach the grounding screw. Piece of cake once you know what the issue is :)
Thanks!!!!
SAL
