Sharpening a squarewave
Mark Roberts
I am currently generating audio frequency squarewaves in the audio
editing software "CoolEdit". Although there are others that will do
the same job.
However, I need something more harmonically pure for test purposes,
ie. a squarewave that is perfectly rectalinear and has virtually
instantaneous rise and fall times.
It needs to deliver a 12V swing and hold up under a 16 Ohm
non-reactive load.
What type of circuit can I add to my soundcard output that will do
this best?
Mark Roberts
Phil Allison
"Mark Roberts"
the same job.
** You must come up with actual rise and fall time figures.
If that doesn't strain your tiny brain too much.
non-reactive load.
** A power amp IC may be OK - depending on your rise and fall times.
this best?
** A "Schmidt trigger " will sharpen up the rise and fall times of your
existing signals.
However, you MUST come up with actual rise and fall time figures.
Justify them too.
All sounds like a giant wank, so far.
........ Phil
Eeyore
the same job.
non-reactive load.
this best?
Your sound card output is band limited for very good reasons. It won't make a
truly sharp squarewave.
Graham
DaveM
the same job.
non-reactive load.
this best?
Mark Roberts
A harmonically pure square wave??? Now, how in the world is that possible??
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Life is like a roll of toilet paper; the closer to the end, the faster it goes.
Phil Allison
"DaveM"
** No harmonic missing - of course.
Right out to fucking infinity ..........
Beam me up Scotty .........................
....... Phil
martin griffith
"DaveM"
...... Phil
It's
"Scotty, beam me up"
martin
Don Lancaster
Phil said:
"DaveM"
You mean like the second, the fourth, the sixth, and so on?
The simplest way to get a square wave with very good symmetry is to us a
binary divider.
http://www.tinaja.com/magsn01.asp
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
F
Fred Bloggs
Mark Roberts wrote:
[..snip...]
Rectal-in-ear huh? You must be British!
non-reactive load.
View in a fixed-width font such as
Courier.
Phil Allison
"Don Lancaster"
** Why.
Since their absence would be no surprise to anyone.
Just like your brainless ASD fucked crap.
**** head.
...... Phil
MooseFET
the same job.
non-reactive load.
this best?
I am sort of surprised that nobody has already suggested this. If you
have a comparitor to turn the sound card's output into sharper
squarewave, you may still be off the 50-50 duty cycle mark. A good
way to solve this is to use a flip-flop such as a 74HC74. This will
give you a squarewave with the needed duty cycle but at 1/2 the
frequency. Since the sound card can be programmed to make twice the
frequency, you should be able to work with this.
There still can be a bit of timing shutter on the output of the sound
card. This is likely to go away when the cycle of the signal is an
integer multiple of the sampling rate. Since this is true at many
values you can just be selective in what frequencies you use.
Paul Hovnanian P.E.
martin said:
[snip]It's
And then never actually used during the original series. "Scotty, beam
me up" wasn't uttered until they put it in one of their movies.
Rich Grise
martin said:
[snip]It's
I did hear, "Gentlemen, I suggest you beam me aboard" on the one with
the neutronium doomsday machine.
Cheers!
Rich
