shunt precission question
smilem
Jan 5, 2013
65
For example, note the
battery monitors are specified as:
Volt ± 1% + 2byte / Amp ± 2% + 5byte
wattmeters are specified as:
Volt ± 0.1% + 2byte / Amp ± 0.5% + 3byte
So in general I understand that typically you don't need 0.5% for battery measurements because of repeat-ability error.
But Victron Energy makes 300Eur meter 0.01%, maybe their stupid or make it because it's so expensive.
If measuring capacity of Lithium cells the 0.5% accuracy is more than needed I guess. The battery monitors and wattmeters by this seller are the same except the battery monitors can measure reverse current so no need to disconnect anything when charging and loading the battery for test. The wattmeters are more precise and will need to be rewired for each cycle.
50A
http://www.ebay.com/itm/DC-0-120V-0...313281?hash=item27dc9280c1:g:imAAAOSwHQ9WXb5G
100A
http://www.ebay.com/itm/DC-120V-100...294165?hash=item27b1989fd5:g:gWUAAOSwyQtVz1vp
