Siemens Gigaset 2415 question
parallax
I have a Gigaset 2415 as well as one Siemens 242 unit. They are both
2.4 Ghz.
I tried to make 242 work with 2415 as an add on unit, but it can't find
the channel.
Is there a way to make them work together?
Scott Lane
parallax said:
2.4 Ghz.
the channel.
Go to Siemens.com and download the owner manual for the 2415. Follow the
directions to register a handset. You may want to de-register the handset
before you try and register it on the 2415. Good luck. Scott
parallax
The manual says to turn off the registered unit and to place the other
one close by.
I did it, and the 242 unit displays "Out of range" which means it
cannot "see" the base signal. Siemens 242 does not have the extensive
menu that 2415 has. Maybe they are not compatible...
Similar threads
