Silencing a humming transformer ( + ACDC adaptor that blew )
I have no experience with electronics except dabbling with a
multimeter.
I wanted to silence a humming transformer, I read somewhere that
covering it in JB Weld would do the job. But I didn't even get that
far.
I struggled to open it up, in the end I managed it quite 'easily' with
a hammer.
Before even putting on any JB Weld, I put the lid back on it and
plugged it in.
Then I flicked the mains power switch and bang it blew.
I know it was the ACDC adaptor because and not a mains plug fuse
because the power cord still worked in another ACDC adaptor
Is there a way for me to open one of these things without encountering
that?
does anybody know about silencing humming / whining transformers
**THE-RFI-EMI-GUY**
I think You were quite sucessful in your effort to silence that
transformer! Using a hammer was very creative! I have found that a
hammer is usually not effective way to get into those things, so you
surely had a big hammer. Perhaps it would be safer to buy a new one. For
future reference, you can often silence a noisy transformer with a small
shim or wooden toothpick between the core and the windings. Dont use so
much force that you cause the wires to short out or break. Noisy
transformers can also mean that there is a bad diode or electrical
short. This may cause a safety issue. Repairing "wall warts" or AC/DC
adaptors is seldom worth the cost and is often unsafe.
multimeter.
far.
a hammer.
plugged it in.
that?
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
"Treason doth never prosper: what's the reason?
For if it prosper, none dare call it treason."
"Follow The Money" ;-P
first eliminate overload/shorting as a possible cause of hum. Then any
of the following:
wedges between core and bobbin
hit the edge of the core with a hammer & cold chisel to jam the lams
together
put glue or tar on the lam edges
NT
PeterD
multimeter.
far.
a hammer.
plugged it in.
that?
Man, I'll get blasted for this one!
Drill two small holes (carefully) into the case, near the edges.
Position with holes up.
Mix up some epoxy.
Inject the epoxy into one of the holes until it comes out the other
one.
(alternative: one of those devices that both mixes and injects the
mix.)
Wait for a few hours after the epoxy sets to test.
No warranties expressed or implied on this one... <bg>
**THE-RFI-EMI-GUY**
Did anyone notice he was using JB Weld epoxy? I think that stuff has
metal particles in it!
Mix up some epoxy.
one.
mix.)
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
I haven't used it yet. I have a few cheap rubbish ACDC adaptors most
or all of which make a noise. I broke one as described, but i'll try
to experiment on the others too.
http://jbweld.net/products/jbstik.php
it says it's an insulator.
I will reply to my post with links to pictures of the transformer.
<snip>
James Sweet
<snip>
Regardless there's a lot easier epoxies to use. JB Weld is very thick
paste, you can get liquid epoxy resins which will be much easier to pour
into something.
multimeter.
far.
a hammer.
plugged it in.
that?
Here are pictures of the transformer
http://img152.imageshack.us/img152/262/15084473gh0.jpg
http://img339.imageshack.us/img339/954/18933823la0.jpg
http://img339.imageshack.us/img339/3033/19265605dw7.jpg
I know the AC-DC adaptor sits on a book about electricity, but it
hasn't been read, I don't have any background in the subject!
into something.-
thanks for the tip, i'll be getting some.
I posted some pictures of the transformer, I can't really get to it..
The copper coils of wire seem to be covered in some yellow thing and
aroudn the whole thing there's this square housing with yellow tape
over it.
But, just to get an idea of where i'd pour the stuff.. if I could.
Here is a picture of another device I once had. The transformer was
'naked'.
It was a power supply card.
http://linitx.com/product_info.php?products_id=397
you can click the image to enlarge it.
Alternatively here it is
http://img72.imageshack.us/img72/38/aazc0.jpg
There were a couple of transformers on it as you can see.
I think if the transformer is shaped like a doughnut. With my AC-DC
adaptor, the wires go round in circles that are sort of parallel with
the PCB. They go round the circumference of the doughnut. (at last I
think that's what they do, i'd have to pull off the housing to get a
better look)
Whereas on the power supply card that I linked to, the wires are sort
of perpendicular to the PCB.
In the case of the power supply card, would I pour liquid epoxy in the
middle. WHat is actually causing the hum? The coils hitting the
doughnut(core?)
I just googled transformer coils core into google images. And got this
amazing picture
http://img.alibaba.com/photo/11498927/Transformer__Coils__Inductor__Line_Filter.jpg
or for the archives
http://img135.imageshack.us/img135/3100/transformercoilsinductooq8.jpg
I see the one in my AC-DC adaptor in that picture. It's second row
from the back. And second , maybe third, from the left !!
**THE-RFI-EMI-GUY**
It does say it has "steel reinforcement" in it. To what extent it might
mess with a linear or swiching power supply, I couldn't guess. I would
use a different epoxy if in doubt.
<snip>
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
John E.
I've heard that using a light oil (be sure to find one that doesn't stink!)
-- just a few drops -- will lubricate between the lams and quiet a hummer.
Good luck,
Ross Herbert
Unless I'm mistaken the transformer you refer to is a fairly standard
E core ferroxcube switch mode type. The cores are generally stuck
together with epoxy or other suitable adhesive at manufacture. If the
adhesive between the faces of the two E cores comes adrift you will
hear a high pitched squeal and possible even a rattle. I would not try
to fix this by covering it with any sort of gunk (or JB Weld). The
transformer should be unsoldered from the board and the two E cores
removed, their mating faces scraped clean and then re-glued under
pressure.
Sometimes only one face may have come unglued so you have to heat the
transformer core to a reasonably high temperature (I use a hot air
gun) in order to soften the remaining bonds so you can get the cores
apart.
Re-gluing with epoxy adhesive is good and will definitely fix your
squealing transformer. I have also used Cyanoacrylate (superglue) to
rebond core faces.
default
<snip>
We used aluminum filled epoxy to make nearly bulletproof modules for a
military contractor. The aluminum made it transfer heat well - but
some of the modules would fail the high potential test as a result of
the metal content.
An unfilled epoxy would be safer. or mix some non- conductive non
flammable filler in like sand or chopped glass or ceramic micro
balloons,
PeterD
I don't think JB Weld had metal in it, but I've seen metal in epoxy
cause some rather interesting problems! <bg>
James Sweet
Jim Land
That's a switchmode power supply....
Switchmode power supplies do not hum. (Where "hum" is defined as a 50 or
60 Hz, or 100 or 120 Hz sound.) They operate at much higher frequencies.
Which is the whole point of a switchmode power supply: higher frequency
means less iron.
Original poster: What did you hear from this power supply that got this
whole thing started? Describe the sound.
means less iron.
here's a recording , putting my mic near it
it's an mp3 file about 1 minute long
http://tinyurl.com/3xsuay
around 11-15sec is probably most representative, i.e. quite high
pitched. Though it's quite a bit higher than the recording has it.
into something.-
putting aside the fact that it may be a capacitor humming. I may have
other devices with transformers like that and they may hum. How and
where would I put anything into that transformer? The transformer is
surrounded in an outer casing.
I tried soldering the transformer off (was a cheap acdc adaptor and
that particular one I had was already blown). It didn't come off, so,
I plied it off with a screwdriver, for the sake of getting a better
look at it. Either way, whether it's on the board or off it, I can't
see where i'd be putting the epoxy. The whole thing is surrounded in a
square shell.
I linked to a pic of it here
second from left second row from back.
And is a noisy capacitor solved with epoxy?
thanks
Guest
put the adapter in the refrigerator for an hour or two
find the seam that closes the outer halves.
lay the thing on a concrete surface, (it must be absolutely non-movable)
gingerly whack exactly on the seam, go rouund it a few times
most ultrasonically welded units will fracture at the seam, some chemically
bonded will refuse to open, they require a jewelers hacksaw to splitt the
case.
whenu get inside, dip the xformer in a good brand of varnish, then bake the
thing for a couple hours at 250F in an oven
most buzzing is caused by poorly wound (looselywound) wires around the core
that migrate as the unit experiences warm/cool cycles. some thinly applied
manufacturing varnishes fail easily and then the insulating varnish on the
actual coper wire wears and then you get a nice short that often will
entertain u with a bang or flash or complete destructive fire of your
home/business ;-))
all good reason to buy good adapters whenever u can
