Simple LED fader
ryan
Feb 6, 2011
Hi there! I'm looking to build a little project, but I don't really know where to start.
I want to have 3 fader-type potentiometers that will control the R, G and B parts of an RGB LED. I have a bit of experience with micro controllers and it's something that would be easy with that, but I want to build it as an analog circuit.
The things I know are this:
I'll need to use a transistor to control the voltage to the LED from the battery, as a pot would die a quick death otherwise.
Any one have any tips regarding how to start? Should I just breadboard something up and try things until it works?
Thanks!
You really want the pots to control the current of a variable constant current source.
Basically, you have a sense resistor in series with the LED and you use an op-amp to compare the voltage across the sense resistor with the voltage on the pot.
An alternative is to use the pot to control the duty cycle of a PWM signal used to power the LED(s).
ryan
Feb 6, 2011
right! I want to eventually make this something that I could produce cheaply (by hand) and sell. Also I want it to be quite compact, so I'm shooting for non-chip construction. Is it possible to create a PWM signal w/o a microcontroller? Maybe just an IC w/ osc?
By op amp you mean a transistor right?
Thanks for your help. Very useful.
By op-amp I mean op-amp. They're "chips" (or ICs -- I don't get your distinction). Basically a device containing a stack of transistors that provides you with a high gain amplifier that can be used for all manner of purposes.
Perhaps the simplest oscillator you can make that can have its duty cycle easily varied is one involving a 555 oscillator. Again, "a chip", but saves you heaps of effort and can probably drive most LEDs directly.
