Simple question, is this correct?
feelsguy
Apr 16, 2014
4
Unsure as to whether this answer is correct? - Cheers
duke37
Jan 9, 2011
5,364
I have not worked through the circuit but I do not think it right.
Also no gate output should be shorted to ground.
Laplace
Apr 4, 2010
1,252
There are two questions that must be answered:
- 1. Does Vgs of the MOSFET need to be high or low to turn on the detector?
- 2. Which side of the bi-stable latch goes high or low when the button is pressed?
When you can answer those questions, make that connection.
And why would you connect the output of a device directly to ground?
