Simple serial to IrDa
explorador
Oct 3, 2006
13
Hi, hope this is the right place to ask for advice.
I use a GPS with my pocket pc via serial cable. It is a simple connection with only 3 cables. Now I moved to a Palm Tungsten T|X. By the documentation it seems the serial wiring is not that simple and not really a standard serial connection, risking my gps and my palm.
So, Palms have a Infrared port.  It comes to my mind to send the serial signals form the GPS via serial-infrared. I found this  http://iguanaworks.net/ir/serial/ and the page states it is designed to work with THAT software... not like a standard serial to infrared.
Is there any simple way one can convert the 3 cable connection to Irda? Its only involved the RX,  TX and Ground wires. No handshaking needed.
I found some serial to IRda on the web but I don't know if they need all the pins to work (power and so). The GPS has only 4 pins, 3 are used to send data only.
any advice?
