Sola Constant Voltage Harmonic Neutralized Transformer - Buzzzzzz
  • Thread starter T o d d P a t t i s t
  • Start date
I've got a Sola Constant Voltage Harmonic Neutralized
Transformer that I use as an isolation transformer when
working on TVs. It's heavy enough that my grandfather put
wheels on it and a pair of handles to move it around. The
fact that granddad did it tells you something of its age.
It's always hummed, but the hum now seems more like a roar.
I know old transformers tend to delaminate, but is there
anything that can be done to tone it down? When I switch it
on, it tends to scare everyone in the room more than the
open high voltage in the set under repair.
Bob AZ
Yes they do this.
The cure is to remove the transformer part from the case and all, tape
the leads together to enclose them and take it to a transfromer shop
where they will encapulsate it with epoxy. Put it back together and it
will be quiet as a mouse. Be sure to label/mark the leads when
disassembling.
Bob AZ
