Drew Cutter
- Jan 1, 1970
- 0
Could some one point me to a solar powered cement mixer ?
Solar powered? Humm.. I dunno..Gìmmìe Bobbie said:Niagra Falls?
Maybe you could,uhm, "adapt" a 12/24V washing machine/dryer or
something? (I assume they'd have a decent sized DC motor in there..)
I wouldn't try mixing a large load in it..
I know they make portable gas powered mixers..Dunno where to get
one,other than the local equipment rental place.
Drew said:So far all i've seen is electric or gas.
Got alot of batts/PV panels?
Get a large inverter,and use an electric one..?
Steve said:I don't think a 1200 watt unit is going top handle the startup load of
that 1/4 hp motor. Put an amp meter on it (clampon is fine) lock the
rotor shaft, and see what it draws. A 2500 watt unit with 5000 watt
surge might handle it just fine. $269 at BJ's wholesale, if that motor
is happy on MSW. Our 1/2 hp water pump works ok on this inverter.
Steve Spence
Dir., Green Trust
http://www.green-trust.org
Contributing Editor
http://www.off-grid.net
http://www.rebelwolf.com/essn.html
Drew said:How big is a larger inverter ? cost ?
Gìmmìe Bobbie said:Weight may be the cost factor.
Can lead acid be discharged...drained and sent successfully and then
refilled and charged at the other end or how would that be done?
I think it can be done..
Can they get acid in Africa easily?
I wonder if you could talk to a manufacturer,and buy dry
batteries,perhaps that would be better than draining/refilling?
Hmm..you might have to charge them under a watchful-eye to "form" the
plates (oxides) after you fill them,but that shouldn't be too hard..
(I think they usually do that at the factory,after the fill them.)
I dunno.
