Solartron 7150 Manual needed.
N
njkenworthy
Looking for an E-copy of a Solartron 7150 manual OR a clue as to why the
unit is only responding to the keypad in columns as opposed to as it should
as a matrix. ie keypad is 3col x 4row matrix but only 3 functions available,
all keys in one column produce same reult.
All functions available via GPIB and all scales/ranges in good order.
Joerg Hau
Hi
the unit is only responding to the keypad in columns as opposed to
as it should as a matrix. ie keypad is 3col x 4row matrix but only 3
functions available, all keys in one column produce same reult.
The User's Manual does not say anything about such a state ... in
other words, this is not "expected behaviour". If the 7150 is _not_
in local lockout state, every single key (mode/range settings etc)
should react as you expect them to do.
Just to be sure: did you disconnect it from the GPIB bus? You did not
accidently - via GPIB - send it into calibration mode (where it would
no longer react to the front keys either)?
Cheers + HTH,
- Joerg
