Solder Paste Flux?
Ron J
Hi all,
I just went to local electronics hobby store and got GC Electronics
Soldering Paste (Flux). I'm now confused. The container says Soldering
Paste, but right above it says Flux. Did I just get a Flux material or
does this contain solder, as well? Can I use this Soldering Paste /
Flux material for toaster oven reflow?
Thanks!
Chris
Ron said:
Hi all,
Thanks!
Hi, Ron. Could you provide the GC part number?
Chris
Ron J
Hi Chris,
I can only find GC 10-202 on the container. More accurately, it says
"Water Removable Soldering Paste" with "Solder Flux" written on top.
The directions state:
1). Apply Water Removable Soldering Paste
2). Heat
3). Then add GC's pure non-leaded solder
So, I'm guessing this is just a flux? But if that's the case, why do I
need to heat the paste first?
Thanks!
Chris
Ron said:
Hi Chris,
2). Heat
Thanks!
Hi, Ron. GC 10-0202 is a water cleanable, organic flux made to be used
with a lead-free solder. I'm not sure if GC Waldom still sells that
kind of solder. You can still use it with leaded solder, as long as it
either has no flux core, or has an organic (water soluble) flux core.
http://www.gcwaldom.com/catalog.html
Look on page 16 of the Chemicals section.
Flux is a good thing to have on the bench, because many times the
circuit board pad has become somewhat oxidized, or the component isn't
easily wettable for some reason. Also, extra flux usually means you
don't have to heat as long to get a good solder joint. The small
amount of flux in the solder wire core may not be enough to clean the
surface of the pad.
To use the flux manually, apply it to the circuit board or area to be
wetted. Apply the soldering iron to the area for a brief time to heat
up the flux (it becomes reactive at higher temperatures, and is
relatively inert at room temperature). You usually see it bubble, or a
small amount of smoke will come of the flux as it's heated. Then apply
the solder to the jointand release both the solder and iron as the
joint is formed. The flux cleans and chemically activates the metal
surface, making it more easily wettable by the solder. Otherwise, you
might just have a blob of solder sitting over a dirty pad or component
wire, with either poor or no electrical connection.
The advantage (such as it is) of organic water-soluble fluxes is, of
course, that the residue can be cleaned after soldering without using
banned solvents. This is something of an advantage, but organic fluxes
are less inert than rosin at room temperature, and can cause conductive
paths across the circuit board. Also, they can be kind of aggressive
at elevated temperatures, causing etching of traces under SMT
components that get hot. So, with organic water-soluble fluxes, you
really should make sure to clean the boards in water after you're done
(I like to use Palmolive Green in warm dishwater concentrations with a
brush, followed by a straight hot water rinse and warming oven dry).
Also, this is a water-soluble organic flux, so you should avoid mixing
it with rosin-based fluxes. Neither one works as well when they're
mixed, and you usually end up with something that doesn't work or clean
very well. Most wire solder has a flux core, so you should check
before you use it. If you want extra flux with a rosin core, use
GC-10-4202 liquid solder flux.
I hope this is the explanation you were looking for. If not, please
post again.
Chris
Ron J
Hi Chris,
Thank you very much for the informative post!
I have a Radio Shock solder that says "Silver-bearing solder." I don't
see any indication of rosin-based flux. Will this work with the GC
paste?
Also, to clean the board with water, do I need to use distilled water
and not tap water?
Thanks!
Chris
Ron said:
Hi Chris,
paste?
and not tap water?
Thanks!
Again, a part number would have helped. The website shows two current
selections for "silver bearing solder". 64-035 shows rosin core on the
webpage. The other, 64-013, doesn't show anything. It may or may not
have a flux core.
If the label on the package doesn't say anything, you might want to
take a razor blade or sharp utility knife and make a non-perpendicular
cut in the wire. If you see something that looks like a hollow core in
the center of the wire, it has a flux core. You then should determine
whether it's rosin or organic. Failing everything else, if you happen
to know what standard rosin flux smells like, just touch the tip of
your hot iron with the solder and take a sniff.
However, it really should say on the package.
I would doubt Radio Shack would sell solder with organic flux (it's
quite a bit more hazardous than the rosin stuff, and they do have
lawyers), so if it does have a flux core, you probably shouldn't use it
with your organic flux.
And if you're near the Radio Shack, you may want to look at Catalog #:
64-022. It's a 2 oz. Non-Spill Rosin Soldering Paste Flux, if you have
to have some. But as I said, most solder comes with some kind of flux
core, and that's sufficient for most electronics work.
By the way, if you are going to be using the Palmolive cleaning method
(recommended by Bob Pease of National Semiconductor, along with the
dishwasher method), plain very warm tap water should be adequate for
most stuff. Use lots of it to rinse off any residue. Another pass
with the brush while rinsing isn't a bad idea, either. Make sure,
though, that everything on the board can be water-cleaned. Many
things, such as pots, relays, switches, &c., will retain the water, and
then cause you grief when you turn it on. Either that, or washing will
remove lubrication, or cause oxidation. If you have these components
on board, you have to install them after water washing.
Good luck
Chris
Ron J
Hi Chris,
Thank you again!
I found this page:
http://www.seed-solutions.com/gregordy/Amateur Radio/Experimentation/N2PKVNA/SMT.htm
In it, the author mentions that "the solder is 0.015 inch
silver-bearing solder made by Radio Shack (64-035E). In general, silver
solder is becoming more common because there is a drive underway to
remove/reduce lead from all products. While silver-bearing solder may
have slightly improved conductivity, and it is much stronger than pure
tin-lead solder, it does have a slightly higher flow temperature. Note:
this solder, and as best as I can tell, all solder of that thin
diameter, do not have a rosin core. The solder is simply too small to
support a core of flux."
I have the same Radio Shack solder. However, when I search on the
website I only found the one that you mentioned 64-035...and not
64-035E. I wonder if they are the same. The picture on the RS website
does have the same marking except for the extra E on the part number.
Chris
Ron said:
Hi Chris,
Thank you again!
I found this page:
Hi, Ron. I'm not familiar with Radio Shack solder. I've got a few
spools of Kester (a 1 pound spool will last forever), and use those.
The 64-035 is eutectic 62%-tin, 36%-lead, 2%-silver solder, not the
lead-free type. The silver is useful in SMT soldering to help prevent
leaching from the component terminations, a big problem with hobbyist
work. The 64-035 is also .015", and _does_ have a rosin flux core.
Again, use a new razor blade to make a diagonal cut in the solder wire,
and you should see it kind of fold in. Or just touch it to a hot
soldering iron. If there's no flux, you won't see any wisps of smoke,
hear any hissing when it melts, or get any smell off the solder. All
flux is chemically active when it heats up, which means that it will
give you an odor. I would think RS would give a different part number
if they made a major change to a solid wire solder.
For manual SMT work, it's better to use some kind of extra flux, if
only to help avoid overheating of components. If that's what you've
got, you might as well try it. But you should get a feel for using the
different types of flux, and choose one or the other if you're going to
be doing this regularly. I'll use Kester "44" whenever I can for
prototype and repair work, but if you need to clean the board, common
sense as well as consideration for the environment might lead you to
use the water-soluble organics.
Good luck
Chris
