Solving Digital TV Interference
David L. Jones
Ok, I love my digital TV, but interference from other stuff in the
house is really starting to bug me. Almost anything that switches on
and off will usually interfer in some way (lights, dishwasher, fridge,
appliances etc), and the roller door shuts the box down completely.
Anyone got a good solution that has worked for them?
I've heard about earthing the coax shield to a separate copper pipe,
any success here?
Dave :)
atec 77
any success here?
Dave :)
borrow a cheap ups and isolate the digital gear with that , you may need
to earth the gear and coax on a separate telecommunications style earth
but a combination of both should kill the problems .
Mark Hathaway
Howdy Dave,
are you using quad shield coax?
If you are using a combo yagi antenna with band 1,2,3 and 4 tuning it will
pick up great amounts of interference, such as cars ignitions, dirty power
pole insulators, switching noise form around your house, etc.
Here is a great resource for antenna selection
http://www.dtvforum.info/index.php?showtopic=12098
As soon as I moved to a log periodic antenna , I solved my signal
level/quality issues, and since cannot produce any picture/sound corruption
from local switching, etc
I'm deep in a gully up in the Dandenong Ranges of Melbourne, the
transmitters are only ~5km away but my log periodic is aimed 120 degrees off
the imagined line of sight to the transmitters, picking up a reflection off
a gum tree covered hill. I'm the only person in my street with digital SBS!
Regards,
Mark
David L. Jones
Mark said:
Howdy Dave,
Hi Mark
Yep, brand new quad shield (and F connectors) all the way through the
house. Just standard coax from the wall to STBs though.
Yes, I'm using a digital capable combi.
Don't want to change it though as it's less than a year old. I choose a
combi because at the time I had one STB and one analog TV, now I've got
two STB's, but can't really justify a new antenna unless it is the only
thing that will solve the problem (unlikely).
In this case I would guess that it was the increase in signal strenth
that did the trick.
I suspect that I won't be able to fix my problem with an increase in
signal strength, as my antenna is already a high gain "fringe" type and
I'm getting >80% signal strength on all channels, so any improvement
there would be marginal I suspect.
I think I'll start with the earthed coax and work from there.
Dave :)
atec 77
David said:
Hi Mark
that did the trick.
Dave :)
Also make sure your house ground is installed correctly , check the
termination of the wire on the ground stake.
eltan
Have the similar if not the same problems as you and all I did is turn off
everything TV, STB, VCR etc... at the main and turn it back on and retune
STB again and it work fine.
BTW I'll only using bunny ear antenna and its too troublesome for me to
install outdoor antenna too.
W
Wayne Reid
any success here?
Dave :)
I read the other posts. As you have a good antenna and cable, then the most
likely source of the interference is through the AC wiring itself (switch
noise etc.). The UPS example sounds like overkill. You could look for a STB
with a better designed power circuit - but how would you know.
I tried winding a few turns of the wiring from the plug-pack around one of
those ferrite blocks (the hinged ones - you can get them at Jaycar). This
almost eliminated the problem on my Kross STB. The Thompson STB was never
really as vulnerable to switch noise, but it's plug-pack packed it in (as
they are apparently prone to do).
Try the ferrite thing - they only cost a few $$$. Tell the Jaycar dude what
you intend to do and he'll tell you which one to buy.
If there is still noise, it may be worthwhile cutting the DC plug-pack
wiring and putting a serial inductor and a parallel capacitor as noise
filters. Goole for a simple circuit.
Lots of STBs have this problem by the way. My wife hates digital because of
this.
Hope that helps.
WR
Phil Allison
"David L. Jones"
** First thing to work out is the nature of the interference problem.
If the picture is momentarily freezing or pixelating, then the data stream
is being corrupted due to * in-band* electrical impulse noise ( in-band =
in the same frequency range as the digital transmission). If s not, then
the noise is not in-band at all.
Which channels are most affected ??
In order to seriously corrupt the digital signal, the impulse noise needs to
be of comparable strength to the level being delivered by the antenna - so
the signal strength at the particular reception location plus the relative
gain and directivity of the antenna in use are important. A weak signal is
vulnerable and a strong one is not.
Since the energy spectrum of impulse noise falls with increasing frequency,
the UHF band is far less vulnerable and so too are channels 11 and 12
compared to channels 6 and 8 in the VHF band.
Channels 7, 9, 10 & 2 transmit digitally on channels 6, 8, 11 & 12
respectively.
SBS transmits digitally on UHF 34 ( 571.5 MHz) in Sydney.
In-band noise interference is likely to be picked up directly by the antenna
itself, rather than the connecting cable, in the average house situation.
Improving the cable shielding will not help if this is the case. A communal
antenna system, cabled to many residents in a unit block, may be different
matter since the co-ax cable may run in close parallel with installed AC
power wiring.
Probably, the thing most likely to work for those in average to weak signal
area is a better antenna - one with more gain than the usual general
purpose antenna and designed only for that part of the VHF band from
channels 6 to 12 plus the UHF band.
I note that WES finally have such an antenna on display at Ashfield, for
not too many dollars.
Looks like a strangely overgrown UHF type.
........ Phil
David L. Jones
I've had two Thomson STB plugpacks die.
My Thomson DTI500 is just as vunerable as my new DigiCrystal PVR, and
it seems to happen across all channels, although some channels are more
susceptible than others even though they all have the same (very good)
signal level. Not surprising really given the wide bandwidth we are
talking about. The roller door is the only thing that blats out every
channel completely.
Was going to try that, just didn't have any ferrites to hand. That is
the easiest solution if it works.
Thanks for the input everyone. Looks like there are several plans of
attack.
Dave :)
Allan
channel completely.
attack.
Dave :)
Another Idea Dave,
if you can get hold of a different STB, and see if that does it as well.
Maybe its a Box problem, like poor filtering in the pSu.
DSE used to have a 7 day return policy, so you could buy one, try it and
compare, then return for refund.
Regards
Allan
David L. Jones
any success here?
Update:
I have tried the following:
1) Checked Mains earth - looks fine.
2) Checked for close proximity between antenna cable and mains cabling
- fine, at least 1m clearance, except for the short drops down the
walls where it is much closer. But nothing I can do there anyway.
3) Installed seperate mains earth stake to the coax shield - made no
difference.
4) Changed coax from wall to STB to RG6, so my entire system from
antenna to STB in is now quad shield RG6 with F connectors. Perhaps a
minor improvement, no change in STB receive signal level though.
5) Added ferrites to the power inputs and even coax as well. Perhaps a
minor improvement again.
Basically the result is no joy. Two different brands of STB are still
showing the interence with mains device switching, but it is better
than before, so I have a usable improvement at least.
It really only leaves the antenna I guess, but I'm not changing that
for now as it is fairly new. Guess I'll just have to live with the
problem...
Dave :)
Phil Allison
"David L. Jones"
Update:
difference.
problem...
** The dishwasher, fridge and roller door need to be suppressed
nternally - often just a class X cap in the right spot or X cap plus
50-100 ohm carbon comp resistor in series to act as an arc snubber.
Light switches are not much of a problem unless you INSIST on staring at the
TV screen when you operate one - again X caps or snubbers across each would
fix them too.
........ Phil
David L. Jones
Phil said:
"David L. Jones"
Thanks Phil, have been meaning to do that for a while.
fix them too.
It's not me who's switching the lights, it's the wife!
And of course, due to murphy the interruption occurs just at the
crucial point when Jamie or Adam are about to say something important!
With the PVR I don't even have to be watching when Murphy strikes and
annoys me several days later. Ahh technology....
Dave :)
atec77
David said:
Update:
difference.
problem...
Dave :)
Borrow a ups and see if it improves , I suspect the noise is mains borne
