I have used Elecrow 40 times in the past 9 months.
Their boards are absolutely perfect. Not a single mistake.
They charge $25.00 for 10 to 12 panels 100mm x 100mm, double sided HASL, silk screen .
Always keep your boards to a modular size of 100mm x 100mm and cut them yourself if you have 5 boards on a panel. Allow 70 thou between boards. If you want a bigger board, simply stack 2 x 100mm x 100mm
Cut them with a hax saw and lininsh the edges. Sand to the white line.
The holes are PTH and are 2 thou less than drilled size. If you make it size-for-size, the component will not fall out. This applies to usb sockets, switches etc where the pins are sturdy
For component pins I use different sizes depending on resistor, power diode, switch wires, IC sockets, etc
All the sizes are tied to the component so that when you place a component; the land size, spacing of the pins and drill size, comes too.
When you make a board, you simply pull-apart a previous board. You don't start from scratch.
I only use software where you do all the work.
There is no frustration and the program never FALLS OVER.
