David Farber
- Jan 1, 1970
- 0
A while back I replaced the left and right microphones on my Sony CCD-FX620
thinking that would help clear up the audio distortion when recording a video.
Of course, that didn't help much but replacing the smd caps did fix the
problem. Everything is ok now except the microphones are picking up noise like
a sensitive stethoscope. Each left and right mic contains two small mics that
face each other. I have a feeling that when I removed the original mic's, there
was some acoustic insulation material that had to be removed to gain access to
the screws that were holding the mic's in place. When I installed the new
mic's, I don't think the old material was reusable. I didn't think much of it
at the time but now I'm beginning to think that this is causing the problem.
When you put on headphones, it's very easy to hear the mic's picking up the
normal drum motor noise. My old tapes don't have that noise recorded on them.
Is there some special insulation material that needs to be inserted in the mic
holders? Perhaps behind the microphones? I tried putting some foam material
between the back of the mic holder and the front of the camera but that didn't
make any noticeable difference.
Thanks for your reply.
