Sony CPD-520GS compass module wanted or a IC on it. (SIU-212)
Jason D.
The monitor came in with purity complaint and found remains of liquid
spill made a direct bulleye hit on that tiny standoff board of this L2
board. This L2 board on four plastic standoffs right smackdab in
middle of chassis under yoke.
This monitor depends on it to preset part of convergence & purity
areas when monitor is in different directions.
Wanted either:
The small module is SIU-212, (Location GS001 on L2 board) with two X &
Y coils goes onto the purity board (retangular shaped L2 board is p/n
1-670-493-11).
Or this IC either location: IC1 or IC5001, IC itself is A2538N, one
leg corroded off right at IC's body.
Cheers,
Wizard
Bob Kos
Do you still need this part?
If so, e-mail back to bobkos at earthlink dot net. You know what to
change...
W
wolfhedd
almost sounded like a bad microprocessor to me, but im not the camera expert
by far.
wolf
Jason D.
by far.
wolf
I actually identified that module correctly, it WAS compass module.
The monitor compensates for different directions the monitor is turned
on it's base. Monitor still works before and after but needs this
module to adjust purity basing on compass's data. Hence the small
standoff module is in close center where base Z axis is.
L2 board that hosts the compass module is a convergence & purity
ampifiers board.
Fixed as posted in updated post everywhere else.
Cheers,
Wizard
