Sony GDM-F520 monitor brigthness fix?
Eric_Streame
Hi guys
I'm the generally positive owner of a Son
GDM-F520 monitor. Unfortunately the Triniton serie
often develop problems with the brightness being to high and th
focus/contrast becomes a problem
I've found post that tells about a possible fix
http://www.hutzelman.com/home/hardware/mods/monitor
(the link is down right now, but it describes a resistor called "R459
that it's easy to replace with another one with a higher 4.7-6.
MOhm
Unfortunately none of them were specifically ment for my F520. I'v
opened up and it doesn't appear like the one in the turorial and n
"R459" resistor. I've checked the monitor's technical manual for tha
too, and it doesnt have a resistor with that name. I've even maile
Hutzelman, but he didn't know either
So, not being an electronic wiz at all, I would be exited if anyon
around here has any relevant experience regarding this monitor'
problem
Best regard
Eric :
W
Wayne
On Wed, 07 Sep 2005 11:36:35 -0500,
Hi guys.
I'm the generally positive owner of a Sony
GDM-F520 monitor. Unfortunately the Triniton series
often develop problems with the brightness being to high and the
focus/contrast becomes a problem.
I've found post that tells about a possible fix:
http://www.hutzelman.com/home/hardware/mods/monitor/
(the link is down right now, but it describes a resistor called "R459"
that it's easy to replace with another one with a higher 4.7-6.8
MOhm)
Unfortunately none of them were specifically ment for my F520. I've
opened up and it doesn't appear like the one in the turorial and no
"R459" resistor. I've checked the monitor's technical manual for that
too, and it doesnt have a resistor with that name. I've even mailed
Hutzelman, but he didn't know either.
So, not being an electronic wiz at all, I would be exited if anyone
around here has any relevant experience regarding this monitor's
problem.
Best regards
Eric :)
The resitor to change is R941 on the mainboard. See here
http://www.network54.com/Forum/search?forumid=87612
Wayne
Andy Cuffe
problem.
Best regards
Eric :)
Have you tried running to 'color return' function in the menu? It
fixes the brightness problem on some of the more recent sony monitors.
I think the F520 is new enough for this to work.
If not, I have a pdf of the service manual I could send you.
Andy Cuffe
[email protected] <-- Use this address until 12/31/2005
[email protected] <-- Use this address after 12/31/2005
