Sony hcd-sa30 very hot
JENKI
Jun 5, 2013
3
Hello
I have sony hcd-sa30 home theatre and amplifire are very hot and on speaker stop working after five minutes.
All voltage is OK.
What are could be wrong.
Thanks for help
Janez
Ian
Administrator
Aug 23, 2006
1,486
Sometimes that can happen if the amp overheats (for protection).
Have you got the amp in a confined space and is ventilation adequate? Check that airflow is ok and that there's no dust clogging vent ports. Does the amp remain powered/cool if you disconnect all the speakers?
JENKI
Jun 5, 2013
3
If i have disconnect the speakers, is the same overheating.
Only if I disconnect the the connector on plate dmb 03 witch they are connecting to amplifire, then is not overheating.
shrtrnd
Jan 15, 2010
3,903
Are the speakers the correct ones for your amplifier?
Ian's explanation sure sounds like the problem to me.
