Sony KV-35S26: No Power.
Shawn
Hello. My Sony KV-35S26 television just died. No warning or anything a
it had been working perfectly for the 6 years or so that I've owned i
and I am the sole owner. The only problem is that I had to adjust th
tilt correction to max, but doing so positioned the screen perfectly..
no idea if that make a difference. I've always had it hooked up to
surge protector as well.
I didn't see it actually happen, but it was ON when it happened if tha
makes any difference. I went into another room and came back 10 minute
later and the TV was off. I tried to turn it back on and nothing. N
power, no picture, no audio, no Stand-By light lit or blinking
Nothing. I unplugged it a plugged it in to several other outlets that
know work and still nothing.
I'm hoping I can remedy this problem myself and I'm hoping someone her
has experienced this issue before and fixed their problem. Is there
fuse or anything I can check? Because it acts like I blew a fuse o
something. If there is a fuse, where exactly is it and how do I get t
it? I'm not very knowledgeable about electronics and I don't know th
technical jargon, but I can follow directions and fix this if indeed i
can be fixed. I've messed around and modified other electronics b
following online instructions, so if it can be fixed, I can do it.
just need some instructions on what to do if anyone knows anythin
about my problem.
Thanks in advance for any information.
-Shawn
EDIT: I forgot to add that I also tried to turn the TV on using m
remote as well as the power button on the face of the TV and got n
response
Skype_man
Common failure in these type of T.V.,'s are the
2-2sc4834, 1-2sc4927, 1-vdr-601, 2-vdr-602
(sometimes), 0.1 ohm fusible R607. Not sure if this
is exactly the same as your unit though. There are a
few different chassis. Look at these parts, & you will
likely see they are bad. Sky.
K
kip
Not to mention the reason for failure..
Resolder every thing in the Horizontal drive sections along with
the Flyback Transformer if you don't you can expect those new parts to blow.
kip.
Andy Cuffe
kip.
I've fixed lots of these sets and I've never had to replace the VDRs.
Resoldering the H drive circuit is the most critical thing.
Andy Cuffe
[email protected] <-- Use this address until 12/31/2005
[email protected] <-- Use this address after 12/31/2005
