The Man
- Jan 1, 1970
- 0
Hi All.
My mom gave me a Sony Watchman color tv with an LCD color display.
When I turn on the set and press the button for video, it displays
video, but only on half of the display (more like 45% of the display
is messed). Here is a description of the problem:
Device displays signal, but the bottom 55% is normal signal (or video
if on the video input mode) but the top 45% is streched, as if a
single line of video is stretched over the remaining 45% of screen.
In video input mode the effect is similar except there is no snow,
only blue screen on the bottom 55% and stretched pattern on the top
45%.
Additionally, I noticed that when I adjust the volume when in video
input mode, the OSD at the bottom displays the volume bar, but the
top 45% of the screen is affected in such a manner that the stretched
pattern darkens with each tick to the right of the volume bar, i.e.
when the volume is a full off, the stretched pattern looks stretched,
but as the volume is adjusted, a dark column the width of the volume
unit in the volume bar appears in the top 45% of the screen.
I have looked for burned, leaky or otherwise messed up components. I
found none. Since the same problem occurs on both modes, I do not
think the problem is in the TV subsystem.
So, here I am asking for help and/or oopinions as to what to look for.
Barring that, does anyone have any suggestions as to what interesting
things I could do with this, e.g. remove the TV subsytem and make some
sort of head mounted display or something
The Man.
45%.
The Man.
