edson
- Jan 1, 1970
- 0
Greetings.
I am building a PWM bidirectional variable speed motor drive using 4 x
FQP85N06 MOSFETs.
My question is whether it is kosher to use the internal source-drain
diodes to handle the turn off pulses.
I realize that external shottky diodes would give less heat and higher
eficiency, but it is only a 1A 12V motor and I expect heat will be only
a few watts. Are there other reasons to use external diodes?
Here is the spec for the S-D diode.
Drain-Source Diode Characteristics and Maximum Ratings
Maximum Continuous Drain-Source Diode Forward Current -- -- 85 A
Maximum Pulsed Drain-Source Diode Forward Current -- -- 300 A
VSD Drain-Source Diode Forward Voltage VGS = 0 V, IS = 85 A -- 1.5 V
Reverse Recovery Time VGS = 0V, IS=85 A, dIF/dt = 100 A/uS -- 70ns
Reverse Recovery Charge VGS = 0V, IS=85 A, dIF/dt = 100 A/uS --135nC
Advice appreciated.
FQP85N06 MOSFETs.
Advice appreciated.
