Source for TV tuners? (Sanyo)
- - ex - -
Sanyo Model DS25590
I found one by searching online for a shocking $67.80. Any chance I can
do better than that?
Bill
exray at coqui dot net
Leonard Caillouet
Try Tip Top TV & VCR in Reseda, CA. They sell rebuilt tuners for most
brands at $27 including shipping, assuming you send the old one back for a
dud.
Leonard
David
Are you 100% sure it is bad?
90% of Sanyo tuner problems fall into two classes of failures:
1. Problems on the 33v b+ line to the tuner due to an open resistor, R505 on
a little older models.
2. Solder connections inside the tuner to the pins and grounds.
Only rarely do I actually find the tuner bad, usually the surface mount
prescaler ic inside the tuner. Not a repair for the novice or tv repair
guy, but fairly easy to a fully equipped shop and technician.
David
- - ex - -
No, I'm not 100% sure. Will check further as you siggest.
Tnx,
Bill
- - ex - -
I went back inside to confirm the voltage mentioned and found it ok.
But today I noticed I was getting a bit of reception although the
flickering was too heavy to make it watchable.
I popped the hood on the tuner and found ants had made a colony inside.
Once I evicted them the set performs fine now.
Pic at:
http://www.sparkbench.com/sanyotuner.jpg
These devils love to live inside solid state electronics!
Thanks for all the advice.
-Bill M
brian
Should you need a tuner there's a good place here in Calif. I have
used their tuners and had good luck with them and they are not
expensive. The name is Tiptop and they have a website.
