spatial coordinates
  • Thread starter Vincent BERRIER
  • Start date
V
Vincent BERRIER
I am working on a project trying to locate a
robot moving on a the hull of a ship.
The aim is having the spatial coordinates of the
robot
The robot will test the huge during a dry-docking
and will move on with a max speed of 5 feet/sec.
The ship will be arond 65 feets in length.
I think about using a 3-axis accelerometer
coupled with an other accelerometer for the
gravity.
What do you think about this solution?
Have you other solutions?
Roger Hamlett
robot
gravity.
You won't get the accuracy you need, without spending a massive amount on
the accelerometers, and even then the accuracy will degrade with time and
distance moved. Consider using an 'absolute' positioning system, either
counting wheel rotations on the robot, or (possibly the simplest/best),
having a number of ultrasonic receivers, mounted at fixed locations in the
dock. The robot sends a radio 'marker', and at the same time an ultrasonic
'pulse'. Each receiver, responds with the time delay it measured between the
marker and the pulse. You can then work out the distances to the markers. If
you look at commercial positioning systems using accelerometers, they
generally use these to give 'instantaneous' motion detection, and combine
the values with an 'absolute' signal at intervals, to avoid the errors
building too far. This then reduces the overall accuracy needed from the
accelerometers, and prevents the errors from building too far.
Best Wishes
John Woodgate
I read in sci.electronics.design that Vincent BERRIER
I think about using a 3-axis accelerometer coupled with an other
accelerometer for the gravity.
I don't think dead reckoning will work. You will get slip in your
traction against the hull, which will introduce large errors. I suggest
you put a radio beacon, emitting short pulses of carrier, on the robot
and arrange three receivers in a triangular layout. By noting the
differences of time-of-arrival of the pulses at the receivers, you can
determine the position of the robot quite accurately. But even over 65
feet you will need high-speed electronics. Maybe looking at the phase
differences of a CW carrier (as in Decca Navigator) would be better. But
you may not be allowed to transmit on a most suitable frequency.
I suggest radio rather than ultrasonics because the environment will be
very noisy, even above the human audio band.
Tim Wescott
Regards, John Woodgate, OOO - Own Opinions Only.
The good news is that nothing is compulsory.
The bad news is that everything is prohibited.
http://www.jmwa.demon.co.uk Also see http://www.isce.org.uk
And if you do use accelerometers to augment your positioning you'll also
need gyros. As slow as your robot is I suspect that the accelerations are
also slow, and you should just do it all by echo location if you can.
Don Pearce
robot
gravity.
A differential GPS module should do everything you need for this job,
provided the hull doesn't shroud the signal too much. Experiment with
a hand-held to see if it is good enough.
d
_____________________________
http://www.pearce.uk.com
V
Vincent BERRIER
I didn't think that by using accelerometers, it
would be so complicated.
On the other hand, if I use three receivers
(ultrasonics or radio waves) in a triangular
layout, could I get a accuracy of a few inches
maximum?
John Woodgate
maximum?
Yes, using radio wave phase-difference detection, but you will need
careful design.
V
Vincent BERRIER
John Woodgate a utilisé son clavier pour écrire :
you will need careful design.
Do you know where I can find information about
this on the internet?
John Woodgate
Do you know where I can find information about this on the internet?
I tried a Google search for 'Decca Navigator', which gave over 500 hits,
but I did not see the sort of technical detail you need, and the
accuracy figures would not apply to your application. But I feel sure
that the information you need is available. Some people here have
probably worked on such systems and know exactly where to find
information.
N
Norm Dresner
careful design.
I helped design and used a "tri-lateration" system in the '70s that
worked by timing the signal path between an object and three ground
stations. The object carried a radio repeater with a calibrated delay and
the system worked by having each of the three ground stations in turn ping
and receive the response from the object. Since the object motion was
leisurely, successive measurements were adequate. But remember that in
"free space" (and the atmosphere pretty well qualifies), the speed of
"light" is roughly a nano-second per foot. That means that you'll have to
measure the time-of-flight of the pulses to within a single nanosecond to
get 1 foot resolution.
Norm
John Woodgate
(in said:
But
remember that in "free space" (and the atmosphere pretty well
qualifies), the speed of "light" is roughly a nano-second per foot.
That means that you'll have to measure the time-of-flight of the pulses
to within a single nanosecond to get 1 foot resolution.
That's why I recommend investigating a phase-detection system, using CW
transmission. It doesn't necessarily need such fast circuitry.
F
Fred Bartoli
Sure, I've built a sync detector with almost junkbox parts and I can see 1cm
(yes) of coax at 100kHz.
Fred.
V
Vincent BERRIER
Don Pearce a pensé très fort :
for this job, provided the hull doesn't shroud the
signal too much. Experiment with a hand-held to see if
it is good enough.
d
Yes, it's really interesting, but what about the
prices?
Don Pearce
prices?
You should be able to buy a GPS with a Bluetooth radio to get data
back to a remote PC for around $120.
d
V
Vincent BERRIER
Don Pearce a exprimé avec précision :
to get data back to a remote PC for around $120.
d
Great !!!!
Do you know where I could find it?
