spi interface on a TI MSC1211Y5
Dear all,
First of all happy New Year.
The project I'm working on, involves programming TI's MSC1211Y5
microcontroller in C language, to interface with a number of other
chips on the pcb.
One of the functionalities the program is to have, is to receive short
range telemetry data (from a telemetry module). Once the data is
received, it is supposed to be sent to the Microcontroller via the SPI
interface. For this, the telemetry module is the master and the MSC
microcontroller is configured as a slave. Unfortunately the
microcontroller doesn't send any bytes, I've verified this by
outputting the tx buffer on a console window and on an oscilloscope.
However it is able to correctly receive bytes of data from the
telemetry module (the oscilloscope trace corresponds to the rx buffer
data output on the console window). The telemetry module provides the
clock for the exchange, and I've verified on an oscilloscope that it
appears when it should. I've also checked the way the microcontrollers
pins and registers are setup and they seem correct.
The code that I'm using is similar to the examples given on TI's
datasheets.
I was wondering if anyone had any experience in troubleshooting spi
interfaces? I've been stuck on this problem for over 2 weeks and any
help would be very much appreciated.
Thanks in advance for your help,
Regards,
Alan
