Spice Crystal Model - 70MHz
Jim Thompson
Anyone have a reasonably accurate spice model for a 70MHz crystal?
(FUNDAMENTAL)
...Jim Thompson
Tom Bruhns
Jim, seems to me it depends on just what you mean by "reasonably
accurate." For a first pass, I'd use the standard one with a series
inductance, capacitance and resistance and a shunt capacitance. You
can measure the crystal parameters to get a good estimate of the values
of Cs, Ls, Rs and Cp. Crystal manufacturers will commonly spec a
typical and/or maximum Rs and a typical and/or minimum Q and a holder
capacitance which is essentially the Cp. Rs and Q and frequency can
easily be used to find Cs and Ls.
If you want to improve on that, you can add more parts to account for
the inevitable minor parasitic resonances near the fundamental--I think
the usual way is additional series LCRs in parallel with the main one.
And you can add parts to account for the mechanical overtones at
nominally 3x, 5x, ... the fundamental.
If you don't drive the crystal too hard, such a linear model should be
OK, but real crystals, just like real resistors, capacitors and
inductors, are not perfectly linear, and of course they also have a
small temperature variation which depends on the cut angle.
Cheers,
Tom
Jim Thompson
Cheers,
Tom
Hi Tom,
As usual I'm tasked with designing an on-chip oscillator with no
data/model for the crystal :-(
I certainly can roll my own, but I'm trying to get a model as close to
"real" as I can find.
...Jim Thompson
John Larkin
Hi Tom,
...Jim Thompson
Bad news. Motional parameters can be all over the place. It's a
non-trivial task to, say, design a 5 MHz oscillator circuit that will
work with *any* 5 MHz parallel-mode crystal. Series mode is maybe a
little easier, but most crystals are designed for parallel.
John
Joerg
Hello Jim,
(FUNDAMENTAL)
Sorry, I don't. But high-end crystal manufacturers like these guys can
usually provide the correct RLC values:
http://www.kvg-gmbh.de/pdf/Crystals/Introduction.PDF
It's been a very long time but they have helped me out with SPICE data
before.
OT: Checking for flights in and out of PHX. Why is it that Southwest has
many nonstop flights from Sacramento to PHX in the morning but most late
afternoon/evening return flights are lengthy stopover flights?
AWA is the other option but they impose a hefty change fee when the
meeting goes longer than planned and I vaguely recall that you didn't
like to fly with them for some reason.
Regards, Joerg
Jim Thompson
John
I have the advantage of being able to have components for AGC, so
that'll help some.
I've just not done one at 70MHz fundamental before.
...Jim Thompson
Jim Thompson
Hello Jim,
Thanks, Joerg! Looks like a good reference.
before.
Don't know, I haven't flown Sacramento/PHX since Silicon Systems got
bought out.
Regards, Joerg
AWA is now merged with US Airways... how do you like that... America's
Worst (delays) Airline merges with America's most financially unstable
...Jim Thompson
Tim Wescott
(FUNDAMENTAL)
...Jim Thompson
If it's for a specific application can you contact the crystal
manufacturer that the customer plans on using?
70MHz is way out there for a fundamental mode crystal, by the way -- I
think if it were me I'd be making sure I knew how to make it work for a
3rd or even 5th overtone so when the customer calls you back in a panic
you can save the day for them.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
Jim Thompson
It's one of the mesa-etch devices... used in a low distortion
multiplier scheme, to get output at 280MHz.
Part of the problem is that I'm not working for the end customer, I'm
working for a fab... so I'm anonymous :-(
...Jim Thompson
Joerg
Hello Jim,
Didn't know that, I used to only fly long-haul. Southwest is pretty
good. They are somehow always full to the brim but on time. They let you
print your own boarding pass from the web so you can walk right to the
gate and line up. Went to LAX last week with them. PHX will be a bit
tight time-wise this time but if it leads to a longer term deal maybe we
could have a Hefeweizen some day.
One domestic airline that I really like is JetBlue. IMHO they are the
best. No food but everything else just clicks.
Regards, Joerg
Jim Thompson
Hello Jim,
Maybe the scheduling reflects that everyone is leaving Sacramento, but
few are returning ;-)
They let you
That'd be great!
I've not flown them.
Anymore I avoid flying as much as possible. All the security delays
really are a pain.
On March 4 we actually drove to Whittier instead of flying. Our
schedule was tight... picked up "N" at Girl Scout camp at 7AM (MST)
with a fully loaded car, arrived Whittier at 12 Noon (PST), checked
into hotel (prearranged for early arrival), showered, dressed, and
made the wedding at 3PM.
I doubt we'd have made it in time by air, considering parking at PHX,
check-in, fly, arrive Ontario (John Wayne is WAY over-priced), get
bags, rent car, drive :-(
Regards, Joerg
...Jim Thompson
Joerg
Hello Jim,
I'd still request the crystal data or mfg and P/N via the fab. Tim is
right, anything past 40MHz on the fundamental is iffy. Maybe you could
include some nifty circuitry that kind of forces it to run around 70MHz.
Regards, Joerg
Joerg
Hello Jim,
ROFL! Seriously, before the voters kicked Gray Davis out of the
governor's office neighbors moved out of state and the trucker said that
his company had a problem. It was all the empty rides back.
really are a pain.
I got used to it. Driving 8+ hours to places like L.A. is no fun. But
last Thursday the security check line at LAX went all the way out into
the street :-(
One of the things that I really miss from Europe is their fast train
network. The lack of such transportation is a real damper for
long-stretched states like California.
Regards, Joerg
Tim Wescott
...Jim Thompson
I found "mesa etch" on altavista -- interesting. I agree with Joerg --
ask the fab to get you data. I suspect every manufacturer does their
process differently, which is going to result in different crystal
parameters. I think I'd even ask for the data, and the data from their
second source candidate!
Tim Wescott
Joerg
Hello Tim,
2nd sourcing a 70MHz fundamental crystal is going to be a real
challenge. Almost like trying to copy the Stradivari violin.
Regards, Joerg
Jim Thompson
Hello Tim,
Regards, Joerg
The end customer IS the crystal manufacturer.
...Jim Thompson
You can get fundamental mode crystals out to 300MHz - to quote Douglas
Dwyer from here back on Sat, Nov 4 2000 10:00 am - but it used to
depend on using chemical etching or ion-beam milling to reduce the
thickness of the crystal below the levels you can get by grinding.
Thin crystals used not to be cheap or easily available, but if someone
is paying Jim Thompson to design an oscillator circuit, it may be that
that someone has made a breakthrough - or found a reliable way to avoid
making a break through the crystal ,,,
W
Winfield Hill
[email protected] wrote...
Yes, and manufacturers talk about 200MHz fundamental mode crystals.
Har-de-har... I've read that overtone crystals have much higher Q
than fundamental mode crystals at high frequencies, so why would it
be so important to make a fundamental rather than overtone type at
80MHz, er, excuse me 70MHz? (I have 80MHz on my brain right now.)
F
Fred Bloggs
Fundamental mode provides superior phase and jitter noise performance.
Vectron is now boasting high frequency fundamental mode crystals with
less than 150 fs (femto sec) jitter.
