SPICE model for 1N5817 schottky diode?
Chaos Master
Hello..
I'd like to know if someone on this group has a SPICE model of the 1N5817 schottky
diode. I've looked at Motorola (which makes 1N5817) site but they made the design
tool page somewhat clumsy to use and I couldn't find it.
Thanks.
Chaos Master® - Porto Alegre, Brazil
"I am an user of EDA tools and I am ok,
I sleep all night and do layouts all day,
I define initial conditions, I create subcircuits,
I do simulations well."
Terry Pinnell
Chaos Master said:
Hello..
Did you see the datasheet at
http://www.irf.com/product-info/datasheets/data/1n5817.pdf ?
I also saw a few posts suggesting possible alternatives 1N5819, NTE585
and RCA SKE3311.
Jim Thompson
Hello..
Thanks.
I found these in my libraries. I don't know how accurate the model
is. I do note that I removed the "leakage" terms at some point in the
past, indicating I was seeing a problem in simulation.
..model D1N5817 D(Is=2.835u Rs=47.12m Ikf=.3227 N=1 Xti=0 Eg=1.11
Cjo=472.4p
+ M=.6215 Vj=.75 Fc=.5 Isr=37.75u Nr=2)
* Motorola pid=1N5817 case=59-04
* 88-09-12 rmn
..model D1N5817JT D(Is=2.835u Rs=47.12m Ikf=.3227 N=1 Xti=0
Eg=1.11 Cjo=472.4p
+ M=.6215 Vj=.75 Fc=.5 ; Isr=37.75u Nr=2)
* 88-09-12 rmn...modified by JET...leakage terms removed
...Jim Thompson
Chaos Master
Jim Thompson said those words of wisdom from the arcane mages in
sci.electronics.cad:
On Tue, 6 Jan 2004 02:46:27 -0200, Chaos Master
Cjo=472.4p
* 88-09-12 rmn
Eg=1.11 Cjo=472.4p
Thanks. I also found model for UPS5817 (Microsemi part number) which is the same
part.
Chaos Master
Terry Pinnell said those words of wisdom from the arcane mages in
and RCA SKE3311.
I've already found 3 models, 2 thanks to Jim Thompson and one that I found while
following some links in the web site of Microsemi (which makes 1N5817 too).
LTSpice also has this model in it's model libraries. 4 solutions for the same
problem! :D
Thanks for all those that answered!
