Stanley garage door opener problem
Sporkman
I'd like to *fix* my Stanley garage door opener bloody well right, but I
don't have the money to replace it just now. The problem is the (IR)
optical sensor set at the base of the rails, which keeps going out. I
replace 'em ($65), they break again. Act like they're operating
properly (beep when you pass an obstacle through the beam) but won't
allow the door to close. No, the path isn't blocked and yes the beam is
aimed properly. I can hold the bleepin' momentary contact switch button
down and close the garage door, and it opens just fine, but what I'd
REALLY like to do is bypass the bleepin' sensor entirely for the time
being. 'Course I imagine that the opener also has a travel resistance
switch in it and it shouldn't absolutely crush anything solid in its
path, but I'd put it to the test before I left it without the bleepin'
optical sensor set.
Anybody know how I can wire the bleepin' thing to bypass the bleepin'
sensor?
TIA
'Sporky'
Charlotte, NC
Shoreline Electronics
There is usually down and up force settings that will effect opening closing
operation....do you have the manual tat explains on how to set them?
This system wasn't victim of a lightning strike ....was it?
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
Ross Mac
Find out if they are normally open or normally closed sensors. If they are
normally closed....jump em out...otherwise remove the sensor....I would also
make sure I knew where the pets and the cars were before I shut the door. A
friend once put a nice crease in my 65 Mustang with a defeated garage
door!....take care, Ross
Ross Mac
One other note. Make sure that if the sensor is normally closed, you short
the signal and ground...not the power and ground....otherwise there will be
smoke!!! Good Luck, Ross
optical sensor set.
sensor?
Careful there. If there is an accident and it's found out you
defeated a safety feature, you can be sued and/or charged with
criminal negligence.
Just fix them. It might be as simple as marginal wiring or
connections to the opener.
-Chris
Ross Mac
Probably not a problem for a guy that can't afford to replace it!....Those
attorneys really like those Deep Pockets ya know....
Take care, Ross
Take care, Ross
There's a difference between cheap and poor. For example, I'm a cheap
b*stard but I make a fair living.
For the original poster, have you looked at the singles/voltages on
the units? Does the voltage change when something blocks their beam?
