Stepper motor rated power?
eem2am
Aug 3, 2009
429
Do you know what is the rated power of this stepper motor?
It is the 6V, 18.5 Ohms per winding (UBB1/5) type…….
http://www.auf-vertrieb.business.t-online.de/pdf/UBB.pdf
-the stepper has two windings.
Am I right in assuming that this stepper motor’s rated power is 2 * V^2/R = 3.89W ?
If the rated power is indeed this figure of 3.89W, is it ever permissible/adviseable to drive this stepper motor with a power higher than this rated value?
-If so , then for how long may I drive the stepper motor at a power level which is higher than the motors rated power level?
Resqueline
Jul 31, 2009
2,848
Your power assumption is correct if the motor is stopped at a half-step. Running in half-step mode it will consume 3W average. I can't say for how long it'll take this though.
Temporary overpowering tolerance is determined by mass, time, & max allowable temperature. In the ordinary single stepping mode it will consume 2W regardless.
Single stepping mode only applies power to one coil at a time. Half-stepping applies power to two coils simultaneously in-between the single-step positions.
