stereo receiver on the brink...
i have now...TWO...receivers that have done the same thing. they are
stuck in "standby".
does anyone know how to reset them? i am disabled and don't have the
money to get them fixed. will trade for the help though.
W
Walter Harley
stuck in "standby".
Try on sci.electronics.repair.
You'll need to be specific about the make and model, and provide more
details about the failure (eg, did the problem happen gradually or suddenly,
was there any external cause evident, what fixes have you already tried,
etc.). But anyway, post that information to sci.electronics.repair, not to
this group - this is not an appropriate group for this topic.
John Woodgate
stuck in "standby".
You have posted to the wrong NG; it should go to sci.electronics.repair
but you also need to give much more information. Maker and model number
as a minimum.
However, now you are here, unplug them from the mains supply. Wait TEN
minutes (no less!) and plug in again. It often works, but not always.
martin griffith
as a minimum.
They had the same problem on the shuttle today, one of the computer
displays blanked out, after much mumbling they told Major Tom to
switch it off and wait 5 seconds, and switch it back on
No thats what I call on line tech support.
BTW it worked. I prefered my "thump here" stickers
martin
Tim Shoppa
stuck in "standby".
This is the position of the power switch that supplies (reduced)
current to the tube filaments so that they'll warm up faster.
Some amps have slide switches on the back to enable/disable this
feature. In between the main power switch and the slide switch there
isn't much left to go wrong!
Tim.
Tam/WB2TT
stuck in "standby".
Presumably you have tried the switch on the receiver, instead of using the
remote control?
Tam
