U
uriah
- Jan 1, 1970
- 0
I have a piece of test equipment that requires the clock to be stopped
before it can be used on the board your working on. It tests IC in
circuit and I am using it on a 68000 cpu controlled system. One book
said to ground each leg of the crystal and to remove any timer chips
from the circuit to stop the clock. Is this correct or is there some
other way to go about this. Can you ground a leg of one of the pins on
the 68000? will grounding both legs of the crystal cause any damage?
Russ
Russ
