Stopwatch circuit with milliseconds
abuhafss
Aug 3, 2010
348
Hi
I am looking for an accurate Stopwatch circuit with a time resolution of 100ms.
The display is required on 4-digit or 2x2-digit 7-segment LED.
Maximum time 99 seconds.
The circuit may be with or without µC or Arduino.
I prefer separate buttons for Start and Stop but a single button is also acceptable.
I Googled but could not find some suitable option.
Chemelec
Jul 12, 2016
291
Lots of these are Available on Ebay, From China with free shipping.
Many Under $10
Not as Kits, but you can't beat the Price.
kellys_eye
Jun 25, 2010
6,512
Any timer displaying 'seconds' could be readily adapted to mS simply by changing the programmed divisor that produces the 'count' pulse.
In the case of a discrete construction this would mean (for example) leaving out the last divider in the timing chain and getting 1/10th second (or leave two dividers out to get 1/100th second etc) pulses.
KMoffett
Jan 21, 2009
723
"The display is required on 4-digit or 2x2-digit 7-segment LED.
Maximum time 99 seconds."
Sounds like a class assignment.
Ken
abuhafss
Aug 3, 2010
348
Ken
Of course, not.
I need it to integrate it in my project. First I was thinking of utilizing some cheap stopwatch and it was fairly easy to adapt. But I gave up only because of the tiny digits. I decided to built my own circuit but I don't have experience of working with 7-segment LEDs. So I am seeking help here.
I found a lot schematics but almost all of them have 1sec time resolution or displays without the decimal point. Also I have very little experience of programming µC or Arduino.
And by the way, maximum time is 60 seconds (not 99 seconds, my mistake)
kellys_eye
Jun 25, 2010
6,512
The decimal point can be simply hard-wired 'on' as required.
Find a circuit that uses (say) a 1MHz crystal and the 4017 decade divider (or the 7490 - old-school stuff) but instead of dividing the signal down to 1 second intervals simply tap the clock off at the 1mS interval (1kHz point).
1MHz (xtal) divide-by-10 = 100kHz
100kHz divide-by-10 = 10kHz
10kHz divide-by-10 = 1kHz (the mS timing range)
and so on
1Hz - the 'normal' signal used to count seconds.
Many such circuits are designed as frequency counters - the 7490 was a classic for this, used in conjunction with the 7447 BCD-seven-segment driver. Should be loads of schematics on the interweb.
