Strategy to read FIFO of a 16752 rs232 Chip
Steven P
Hi
I need to control a TI 16C752 directly. My question is when the FIFO is
enabled ( it has 64 bytes TX/RX FIFO). The interrupt level can be set
with 8 bytes or 16 bytes, which means only when the data in FIFO
reaches this level, an interrupt will be generated. How can I read the
last bytes if there is no interrupt to triggered the main program?
Some senario:
The interrupt level is set 8 bytes.
1. If only 3 bytes is arrived and no more, there is no interrupt
coming. So I need to poll it with a timer.
2. After the last interrupt, I read all the data in the FIFO. And
after that, 3 additional bytes come. So it is quite same as the first
senario. Because there is no interrupt, I need to poll it with a timer.
I do not like to use a timer. Have any idea?
Another question is while 16752 contains 2 RS232 ports, can I set one
with RTS/CTS enabled, and the other without flow control? I do not find
information in the datasheet.
Steven
Stef
In comp.arch.embedded,
Steven P said:
Hi
Some senario:
All fifo UART's I've used generate an interrupt on timeout (no chars
received for x char times) in addition to the interrupt at the trigger
level. I don't know the TI 16C752, but I don't expext it to be different.
This does mean you can not assume you have gotten at least 8 bytes when
you get an interrupt, it might be less on timeout.
Thank you very much for this timeout information.It is a great help.
With this there will be no problem to get data out from the FIFO.
Steven
