stupid error migrating from pic16f628 to 628A
blisca
In this world we are 6 billions,so there is a reasonablance that someone
else did the same error
i simply turned my programmer(Willepro ,a good amateurish programmer) from
one device,16f628 to another 16f628A
doing this the configuration word that was good for re-programming 16f628
set the 16f628A in protected all mode
well,it is just about 3 ics,less than 6 euro,but i 'm not used to throw away
anything until i'm shure that there are no more ways to recover it
the question is:no way to erase it completely so it can be used more and
more again?
thanks
David L. Jones
more again?
thanks
All of the PIC flash parts (including the 16F628A) can be re-
programmed as many times as you need it. The protected mode does not
prevent you erasing the chip and re-programming.
If for some reason your programmer does not somehow support this then
get one that does. Perhaps there is an option you have missed?
Dave.
blisca
Dave.
thank you but still looks otp-like
i use the configuration word 03A2,after programming the first time i have
the indication "error blowing fuses",and no way to program it again....
i'm desperate ,it is 4:32 am here and i have to finish before 9:00 :-(
AJ
away
more again?
thanks
http://support2.microchip.com/KBSearch/KB_StdProb.aspx?ID=SQ6UJ9A003LD0
I don't like 628's....
petrus bitbyter
AJ said:
As for the configuration bits, /MCLR is enabled so it is not used for input.
As far as I learn from MPLAB, the configuration word "03A2" is accepted for
both the 16F628 and the 16F628A.
It is said that the programming algorithms for the 16F628 and the 16F628A
differ. Both have their own specifications but I did not compare in detail.
It is rumoured that using the wrong algorithm may do damage to the device,
though I did not find a confirmation so far.
AFAIK the only thing you can do is finding another, high voltage, programmer
and trying to perform a bulk erase. I can try it for you, but I don't think
it to be cost effective :)
petrus bitbyter
Marra
MPLAB will erase it for you.
I use the PICSTART by Microchip.
Why buy cheap rubbish instead ?
blisca
Subject: Re: stupid error migrating from pic16f628 to 628A
one good reason could be that at that time willepro fit my budget ,and was a
good choice for the hobbyst,being able even to program other devices(flash
memories,atmel devices and so on)
of course i would like a more microchip-oriented programmer,with the ICD
option
thanks to Marra,Petrus,AJ and David
