substitute car or marine battery in UPS?
Matt
My Belkin 350 VA UPS has stopped working, and I find its (sealed lead
acid) battery is dead and won't accept a charge. I can't say that that
is the only thing wrong with the UPS. The unit is still under warranty.
First I wonder whether it is practical to try to take advantage of the
warranty.
Second I wonder whether I can just use an external automotive or marine
battery instead of the sealed lead acid battery that came built into the
unit. If so, do I have to do anything special when using the external
battery, maybe such as using a separate charger (maybe the UPS's charger
wouldn't be big enough)?
The battery in it is like:
http://www.batterysupplier.com/item.asp?n=LA1245
George Pontis
A separate charger is not a good idea. The UPS circuitry may have the battery
floating at an unsafe voltage, and most external chargers will not even be as good
as the charger in the UPS. (A really good one would probably have a microprocessor
and measure battery temperature)
As far as substituting a different battery, that is also not a good idea. The
sealed lead-acid batteries have different construction than an auto/starting
battery. They also have slightly different chemistry which calls for a higher
charging voltage. An auto battery would draw too much current from the charging
circuitry, would lose water too quickly, and would wear out faster than expected
if it was cycled.
So ... I would first try the warranty. If that is no good, then see if you can buy
an equivalent battery at a reasonable price. You might have good luck with eBay.
You can often recycle the old battery at an auto parts store. These low cost UPSes
go through batteries much faster than would a good design, but people keep buying
them because the limitations are not obvious at the time of sale. Even the mid-
range UPS (e.g. APC SmartUPS) at $400 and up do not handle the batteries well.
ric
Try a motorcycle SLA battery. Something in the 3-4 amp/hr. range.
Conor
warranty.
Err..thats why they have one.
Conor
If Pac-Man affected us as kids, we'd all be running around in darkened
rooms, munching magic pills and listening to repetitive electronic
music.
Jess Fertudei
warranty.
Let the unit charge for a while with nothing plugged in. Then take a low
power light like a Christmas window candle and plug it in. Look directly at
the light as you unplug the supply: If the light stays on for just an
instant then it suggests the circuitry may be good. If you hear a beep (if
your unit has a beeper when it kicks in, of course) it suggests that the
circuits worked but the battery only had 'uuuumpf' for a second or two. This
test is not a guarantee... just a rule of thumb.
Your battery appears to be a 4.5 Amp/hour unit... what it's charger might
need to do to maintain a battery rated 10's or 100's times that might be
more than it can take.
That said... I have read (when wondering about this same issue) some folks
who have done what you suggest, though I've not seen long term reports. My
other thought is not associated to the charger's ability to function, but
rather what about the associated gasses with marine and auto battery
charging? Do you really want these in your home or office's atmosphere on
persistent basis?
I just recently replaced two 7 AH batteries in my 950 AVR. I picked them up
at Batteries Plus and was surprised that the bill was only about $32 US
total. Considering it is a $175 unit, that's a good deal. I saw many
batteries for much higher on the net, and some for the same with and without
shipping included, so research well. Batteries Plus is springing up
everywhere, look here:
http://www.batteriesplus.com/
That said... I just snagged a 350 at Staples for $20 bucks on sale last week
for my son. Back to school time is a great time for UPS, at least in years
past, so watch for them this Sunday.
John Weiss
Matt said:
My Belkin 350 VA UPS has stopped working, and I find its (sealed lead acid)
battery is dead and won't accept a charge. I can't say that that is the only
warranty.
Why not? I got 2 batteries from them under warranty. They even sent prepaid
UPS labels for the returns!
OTOH, I'm not sure I'd buy Belkin again unless the price was WAY right (again);
their monitoring software was a pain, and 2 batteries did fail prematurely...
battery instead of the sealed lead acid battery that came built into the unit.
If so, do I have to do anything special when using the external battery, maybe
such as using a separate charger (maybe the UPS's charger wouldn't be big
enough)?
A motorcycle battery may be what you need; it may even fit inside the case.
OTOH, I wouldn't use a flooded cell battery in the house. Leaking acid and
escaping hydrogen gas could cause MAJOR problems. You would need a deep-cycle
marine GelCell or AGM sealed battery. Though the charger might take a long time
to fully recharge a bigger battery, it would give you a lot longer run time on
battery power. Also, the charger might not be able to properly detect the state
of charge of the battery...
Matt
That makes it practical.
Matt
They will only send me a new unit, and I have to pay for the return
shipping of the old one. My application requires a serial port, and the
new one is USB.
Lyn
You'll probably discover that the battery is NOT covered under the warranty.
default
new one is USB.
There are sealed lead acid batteries available on the electronics
surplus market - mail Internet order
If it were me, I'd get a lawn and garden (tractor) battery. Twice the
capacity of a motorcycle battery at half the cost - and still small
enough AH rating so it won't kill the built in charger.
Sealed battery would still be choice number one - lots safer and
easier on the floor or furniture.
skylinux
Will it work, yes. I live in florida and have done it during the last
hurricane we had in 2004. I was without power for 2 weeks and keept my
Computer running on UPS and generator.
You need a deep cycle battery, don't bother with Car or bike batteries,
they can't handle it.
PLEASE CONSIDER, your UPS is not designed for hours+ operations that you
will get from a large deep cycle battery. You must add cooling fan(s)
and heatsinks here to cool down components that get too hot.
I did not try charging the battery using the UPS circtuit. I used a
proper charger to charge the battery, then connected it and used it.
The UPS I used it on was a APC 1100VA
Skylinux
