Switchcraft 3.5 mm Stereo Jack Pinout
Barry S.
I have a Switchcraft 35RAPC4BH3 3.5 mm stereo jack.
See: http://www.mailsack.org/swcraft.gif
Clearly, there is going to be a left, right, and ground for a headset
and a signal and ground for the microphone.
However, the jack has 5 pins and I'm a little confused as to what they
correspond to in a typical computer audio environment.
_________________________________________________
Replace 'spam' with 'mail' to reply via e-mail
John G.
I think not.
It has a ground, And 2 switched signal connections.
If you look at the plug it has a Tip, a small ring and a larger ground.
The other 2 connections are switched for switching when the plug is
inserted.
John G.
Barry S.
Thank you for the response. Would it be safe to assume for a
headset/microphone:
1 GND
2 Left
3 Left Switched
4 Right Switched
5 Right
Regards,
Barry
John G.
headset/microphone:
1 GND
2 Left
3 Left Switched
4 Right Switched
5 Right
Regards,
Barry
Bottom posts are generally prefered.
Try this link for lots of good info.
http://en.wikipedia.org/wiki/TRS_connector
Or just google Stereo Connections
Google is a good place to start and learn lots of things
John G.
Andy
5 is left, 2 is right.
headset/microphone:
1 GND
2 Left
3 Left Switched
4 Right Switched
5 Right
Regards,
Barry
