Sylvania (Funai) TV 6420FE Goes Off a Second After Turned On
Brad
This "TV" doesn't have a "mode switch". This is NOT
a TV/VCR combo.
I have a Sylvania (Funai) TV model 6420FE (mfg 01/05) in
my shop. Note: I do not have a SM for this set.
The TV goes off about a second after it is turned on. There
is HV and the regulated B+ goes to +115V at turn on. There
is vertical deflection based on the "buzz" sound I "picked up"
near the yoke. I removed the H.O.T. and used a 250 ohm 200W "dummy
load" accross the regulated B+ with the same results (TV goes off).
Anyone fix one of these with the same symptom?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
b
Brad said:
a TV/VCR combo.
Mains switch ?
look for any shorted diodes in the vicinty of the LOPTX- could be
something drawing excess current. check vertical and rgb lines. Also
check any data/clk lines aren't broken - also, the micro or eeprom may
be the problem.
-B.
