Symptoms of Too Small a Start Capacitor for Submersible Well Pump Motor?
Am trying to repair a submersible well pump that blew its start
capacitor because the water storage tank check valve failed. Am glad
to supply all the specifics if needed.
I replaced the blown start capacitor with a new one of same rated size.
Started up pump and it only ran for < 1 minute and pumped ~ 2-3 gal of
water. Same thing happened when the old capacitor was going bad.
The physical size of the new start capacitor is smaller than the one
it replaced but the rating is the same.
Am interested to find out what the symptoms are for too small start
cap. Am wondering if it is better to error on a larger size?
Ken
Sam Goldwasser
Do you really mean "start capacitor"? A start capacitor would only
be used for a fraction of a second until the motor got up to speed and
then would be disconnected by either a centrifugal switch or delay timer.
If it is indeed a start capacitor, then whatever is supposed to disconnect
it isn't working correctly and that's the real problem.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Sam,
After posting was told that the 1/3 hp well pump failed some years ago
and was replaced with same or similar pump but the original controller
box was kept. It is just a basic box with start capacitor, relay and
overload device.
When the check valve failed the pump kept cycling and eventually blew
the start capacitor. When I had the controller box open also checked
the relay which tested OK but was unable to test the overload device
becuase did not have the info. Will do some calling and test because
it is the only part left to be checked.
Have only run the pump 3-4 times since installed the new capacitor. As
mentioned It runs for ~ 1/2 min and pumps ~ 2 1/2 gal water then shuts
off. After a few seconds there is a noise. Sounds to me like
mechanical contacts, do not know if it is coming from the overload
device or relay but am guessing it is the overload device.
Ken
David Nebenzahl
[email protected] spake thus:
overload device.
Yes; probably a thermal cutout switch, I would guess.
Pierre, mon ami. Jetez encore un Scientologiste
dans le baquet d'acide.
- from a posting in alt.religion.scientology titled
"France recommends dissolving Scientologists"
Sam Goldwasser
Sam,
overload device.
I wouldn't expect them to chatter under normal conditions, so that sounds
like a place to begin. The start capacitor should only be in the circuit
for an instant - if you put an multimeter on the highest AC range across it,
there should only be AC for that short time but when it gets disconnected,
there will probably be some DC remaining on it.
lsmartino
Could it be that the motor pump is seizing. The sequence of events
would be something like:
a) The pump tries to get to speed with the capacitor connected. It
reaches the operating speed and the startup relay opens.
b) Without the startup cap, since the motor is seizing, the pump starts
to lose speed and draws more amperage... thus closing the startup relay
again (and the power consumption gets higher too)
c) The pumps gets again to speed. The startup relay opens again, but
the motor looses speed and the relay closes again, thus repeating the
cycle. (this would explain the relay chatter)
d) Enventually the thermal cutout switch opens because of the excesive
current draw.
Do you have an AC ammeter? You should check how many amps is the pump
consuming. That should show you if the pump is within it´s normal
power consumption or not. If the consumption is too high, the motor is
seizing.
Other way to test this is replacing the startup relay by a momentary
contact push switch, and using an ammeter to monitor the power
consumption of the pump. You initially turn on the pump and push the
contact switch to make it start. As soon it gets to speed (probably in
a second or less) you release the switch, leaving the startup capacitor
out of the circuit. Check the amperage, if the pump starts to draw more
an more amperage without the capacitor connected, then you will know
that the pump is seizing.
Good luck.
Sam, David, and Ismartino
Thanks for the suggestions.
First will try to clear up any misunderstanding. Nothing is
"chattering". Will try to be more clear this time. The few times I
have run the pump since the check valve failure, blown start capacitor
and replacement start capacitor have used this sequence. Turn on pump
switch and pump runs for ~ 20 sec and pumps ~ 2 1/2 gals then stops. I
turn off the switch and a few seconds later hear a "contact like
noise"(like relay contacts either making or breaking).
Specifics This submersible well pump is a RedJacket 1/3 hp 230V
single phase 3 wire Model 33 M1. The control box is a "town and
country".
After the blown start capacitor the 1st thing done was to check the
resistance of the motor windings which were OK. Also checked the relay
and it was OK. Since posting was able to get the test value for the
Overload Device and it checks OK. Only problem something is wrong
since pump stops after ~ 20 sec.
As previously mentioned am guessing it is the overload device. When
the pump is running can not hear the relay or overload device
activate.
The only Digital MultiMeter I have is a Sears Craftsman Model 82141.
Checked AC and it lists 10A. Have never used it for measuring current
for a 230V electric motor so will need some hand holding. The specs I
could find for the Model 33M1 motor are
Amps
normal 5.3
idle 3.5
lock rotor 20
Is there some way I can send the schematics? Or are all single phase
230V pump motors with mech relay, start caps and overload protection
the same?
Ken
lsmartino
Without an AC ammeter you can´t diagnose what is wrong. You really
NEED to know how many AMPS are your pump consuming. I still think the
pump has a mechanical problem and it is consuming too much amperage.
You need an AC Clamp Ammeter like this one:
http://www.sears.com/sr/javasr/prod...EARS&sid=I0033900150001800085&pid=03473755000
Don´t *even think* to use your DMM to measure the amperage. The LRA
amp rating of the pump are 2 times the maximum amperage supported by
your DMM and you can blow the DMM.
lsmartino,
Thanks for the warning and link to Sears Clamp Ammeter!
Update found out that the Overload Protection Part was designed to
protect both 115 and 230 Volt pumps. Took it out and everything ran
OK. No shutdowns....
The pump repair person who checked the control box when the capacitor
blew said the overload device was wired incorrectly so after getting
the new cap installed as suggested. Since everything is running OK
with the Protection Part removed and the part tests OK am guessing the
suggested wiring for it is incorrect for 230 V.
The Overload Protection Part is a Klixon TA5 that is no longer made and
Klixon does not have a part that will interchange with it.
Would be interested in any suggestions concerning tracking down correct
wiring for it.
Ken
lsmartino
I couldn´t find anything by Klixon TA5... aren´t there other numbers
on the Klixon protector? Even a picture of the protector would be
great. Maybe TA5 means 5 Amp... but I´m not sure.
If there are other numbers printed on the component, please post them
here.
