Taking 9volts from a wall wort to 1.5volts
Bullwinkle Jones
Hey guys. I've got the following components:
2n3906 xistors
2n3904 xistors
100ohm resistors
18komm resistors
I'm wanting to take 9volts from a wall wart and make it into 1.5volts (or
therabouts).
I'm thinking I could just use the xistors as diodes somehow.. I'm just not
sure how to hook it all up!
A schem on ABSE would be nice, too..
OR if you could point me to a website that would actually explain the basics
so I could figure it out myself!
Thanks a lot!
Clarence
2n3906 xistors
2n3904 xistors
100ohm resistors
18komm resistors
therabouts).
Thanks a lot!
Bullwinkle Jones.
How much current at 1.5 Volts?
How much current it the Wall Wart rated at?
There is also the obvious question, Why? What are you going to use it for?
Bullwinkle Jones
it for?
Not much current needed.. The wart can provide 300ma at 9v. It's going to
be used to power a walkman instead of using batterys. The walkman uses 1 AA
battery normally.. I'm thinkin the current draw won't be much at all.
Thanks!
John Popelish
2n3906 xistors
2n3904 xistors
100ohm resistors
18komm resistors
therabouts).
Thanks a lot!
View with courier font.
+9V in--+----+---+
100 | |
100 | |
| 100 100
| +---+-- 1.2 vout
| 100
| 100
0v in --+--------+-- 0v out
Both transistors 2N3904.
Parallel the lower resistor with 18k resistors to trim the voltage
upward (about 60 mv per added resistor).
If you short the output, some parts will get hot.
Theory: The upper two resistors supply base current to turn on the
two paralleled pass transistors that supply the load current through
their emitters (and balancing and soft current limiting resistors).
When the output voltage rises to two diode drops, the voltage at the
mid point of the lower divider reaches the turn on threshold voltage
of the lower transistor, whiuch shunts all the extra base drive for
the upper transistors ot ground, holding the output at about two diode
drops (or whatever the division ration of the lower divider is.
Clarence
Thanks!
Without more information this is the best and simplest for now.
Like how much current does the walkman draw?
For about25 ma This will work.
Posted on ABSE
Robert Monsen
+9V in--+----+---+
100 | |
100 | |
| 100 100
| +---+-- 1.2 vout
| 100
| 100
When I simulated this circuit, it wasn't very stiff with changes to the
load. Thus, I played with it in spice, and this is the result.
(view with courier font)
9VDC
o--------------------------------------.
o----------------|
| |> output
| o---------------
All Resistors | | | | | |
are 100 ohms | | | | | |
Transistors | '---' |
are 2N3904 \| |
|------------------------o
+--------------------o--------------' '-' '-'
GND '---'
created by Andy´s ASCII-Circuit v1.26 beta www.tech-chat.de
This one was stiffer around 1.5V. Its really the same idea, using
negative feedback to control the output, which I like.
The only real change is the three resistors on the collector of the
rightmost transistor. They are there to dissipate some of the load, so
you don't need two pass transistors and their emitter resistors. Between
1mA and 150mA load on the output, the circuit works with 1/4W resistors,
and the output simulation was between 1.47 and 1.44 Volts, resp. The
pass transistor stays below 430mW; max for the part is 650, but it
should be heat sinked anyway to keep it cool.
Regards,
Bob Monsen
Clarence
9VDC
o----------------|
| |> output
| o---------------
are 2N3904 \| |
GND '---'
Regards,
Bob Monsen
Looks to me that this one will saturate the series pass before you reach
regulation. at 150 ma load
Okay at 75 ma!
Robert Monsen
Okay at 75 ma!
The pass transistor doesn't saturate... those three resistors are
parallel, so 33 ohms at 200mA is 6.6V, which makes the collector 2.4V.
It can go down to 1.8 V, I guess, so it should be able to go up to about
210mA before saturation. Using a 2N4401 would enable it to go even lower.
I simulated it at loads between 1mA and 200mA. It stays within 10mV of
1.5V in that range. The limits are those three resistors, which get to
1/4W at 50mA. Thus, the limit for 1/4W resistors is 150mA. Adding
another one causes the pass resistor power dissipation to go up a bit,
but its good up to 650mW, so its still in the safe zone (if you can keep
it cool.) That means, it can go up to 200mA before the resistors top
out. At that current, though, the regulation feedback circuit can't keep
up. The voltage at the output drops to 1.42V
I'd say its easily good up to 150mA in the configuration shown above.
Above that, I'd go with a regulator IC, cause it'll have current
limiting and overtemp protection, which this one obviously doesn't have.
Regards,
Bob Monsen
Clarence
Regards,
Bob Monsen
Okay. The design was constrained to use only the transistors on hand, and the
two values of resistors. So he got what he needed.
W
Watson A.Name - \Watt Sun, the Dark Remover\
9VDC
o----------------|
| |> output
| o---------------
are 2N3904 \| |
GND '---'
That really sucks. The usual 2N3904 will go into thermal runaway if you
get anywhere near the 310 mW dissipation that they were rated for. Been
there, done that! Use at least two in parallel. Prefereably three.
W
[snip]
lower.
Why can't you people simply READ the datasheet? The _Absolute_Maximum_
current for the 2N3904 is 200 mA, and coming anywhere near that will
cause the gain to drop _drastically_. Just don't push it!!!
have.
Yeah, no doubt it'll go into thermal runaway!
Robert Monsen
According to the data sheet, they go up to max 650mW, derate 5mW/C above
ambient, max 200mA. Perhaps you are reading a different datasheet. I
believe these parts are manufactured by different suppliers.
http://www.fairchildsemi.com/ds/2N/2N3904.pdf
Look at the "Power dissipation vs ambient temp" graph, and recall that I
specified a heatsink for higher powers. At 430mW, the device is within
spec below 150F (65C)
Anyway, we don't know how much power the device requires, so we are
shooting in the dark about limits. He may only need 10mA. He may need
300mA. We don't know.
Regards,
Bob Monsen
Robert Monsen
Watson said:
[snip]
about
lower.
keep
keep
have.
No, thermal runaway happens when current increases with temperature.
That doesn't happen here, because of the feedback.
Clarence
Regards,
Bob Monsen
He was quite clear, it's a Walkman, I got one and measured it. The ONE I
measured took an average of 19ma. I allowed 25ma, and assumed a motor start
current of three times the average.
I usually limit rise in a small device to 25 degrees C, so from 22 the max I
allow is 47 degrees C. It may be built into a small plastic pill bottle.
Clarence
How about posting your simulation?
Which Spice do you use?
I know I can do a simulation that can not be built, and always have to do some
manual checks to prove to myself it's a sane solution.
I'd Like to compare results, and his circuit is simple enough to make it
meaningful and quick.
John Popelish
(snip)> > When I simulated this circuit, it wasn't very stiff with
changes to
the
I agree about overheating the transistors. My design gets stiffer
when you parallel more transistors and emitter resistors, while
cooling them off. I forgot to mention the modularity of the pass
section in my first post.
Without the emitter resistor, it is harder to get parallel transistors
to share equally.
I also doubt that the player needs a very stiff supply. A single AA
cell is not so stiff, either.
