TEAC 1/2" Open-Reel Schematic Needed
Chris F.
I have a Teac Model 80-8 1/2" open reel machine I have to repair for a
customer. This is the first 1/2", 8-track machine I've worked on and it's
clear I'm going to need a schematic. The main problem is that some channels
are sounding through to others; for example, with a signal connected to
channel 1 only, it sounds over to channel 2 and faintly to channel 3. This
happens even when monitoring the input without a tape loaded, ruling out a
head alignment issue.
Any advice, or especially a schematic, would be appreciated.
Phil Allison
"Chris F."
channels are sounding through to others; for example, with a signal
connected to channel 1 only, it sounds over to channel 2 and faintly to
channel 3. This happens even when monitoring the input without a tape
loaded, ruling out a head alignment issue.
** Have you tried shorting the unused inputs while testing ??
This is how the recorder would be used in practice.
..... Phil
F
forte agent
You should be able to get the service manual from:
TEAC America inc
7733 Telegraph Road
Montebello, CA 90640
Parts Department:
voice: (323) 727-4840
fax: (323) 727-7632
e-mail: [email protected]
I do know that they had copies of the manuals for many of their
old to ancient(early 70's) tape machines.
I worked there for a year and a half and they were still repairing
1/4, 1/2, 1 , and larger machines at that time (3 1/2 years ago)
Pimpom
repair for
a customer. This is the first 1/2", 8-track machine I've worked
on
and it's clear I'm going to need a schematic. The main problem
is
that some channels are sounding through to others; for example,
with
a signal connected to channel 1 only, it sounds over to channel
2 and
faintly to channel 3. This happens even when monitoring the
input
without a tape loaded, ruling out a head alignment issue.
http://www.analogrules.com/manuals/tascam.html
Pimpom
Phil said:
"Chris F."
If that doesn't eliminate the crosstalk, I'd suspect a common
power supply filter in the low-level stages. Perhaps a dried-up
cap.
