Tektronix 2230 Power Up Failure
dodger741
If the scope has been off for a while and I power on I get an error
message screen:
Power up Failures
CMOS: Reformatted
If I cycle the power on and off again the message does not appear. I
have run all the diagnostics and they all pass. Everything on the
scope appears to work properly. I can't find any reference to the
message in the service manual. Because of the time it has to be off
(15-20 minutes) I am suspecting a low battery that is used to save
some memory data. I can't fine any reference to a battery for the
basic unit. I did see a battery on the GPIB interface parts list but
couldn't find it on the board or other documentation. Any one know
what this message means??
Jim Yanik
message screen:
Power up Failures
CMOS: Reformatted
IIRC,2230 had a lithium coin cell holder on the top digital board,or a 123
lithium cell underneath the top digital board.(soldered to it)
dodger741
Thanks for the quick response... Is the board you are referring to
the one that has the plastic hinges for tilting the board up. Do you
think the battery might be associated with the message I am getting as
I suggested?
Roger
Jim Yanik
I suggested?
Roger
yes,it's the only board on the top of the instrument.
I don't know about the error messages.It's very possible.
Those batteries only have a 10 yr shelf life.
The 2230 has been out of support longer than that.
dodger741
--I disassembled the unit and looked on both sides of the board. Nothing to be found that looks like a battery. There are two daughter boards attached to the back but they look like some sort of high frequency analog boards because of the metal shield. Strange to think that their is a built in message that they don't mention in the manual! I may never know.
Jim Yanik
jyanik
at
kua.net
Pierre-François
Oups! I'll power up mine these days to look at!
It has not been used since a while as I prefer to use the 2465b and keep the
2230 as spare...
If you find something in the battery area please let us know... I'll do the
same...
pf
dodger741
Still searching for answers. I did find a post on yahoo which listed
a battery idea but also mentioned a low self-discharge current
capacitor. I suppose you could do something like that although I
wonder about the reliability of it. I did search the parts list for
"special" caps and found nothing.
dodger741
Finally I found the battery. It was buried underneath the metal
housing holding the GPIB board next to the CRT neck shield. It
supplies power to the extended memory (26k) which is part of the GPIB
interface. I noticed that the memories on the GPIB daughter board
retained a little voltage when turned off and that their was a diode
in the supply trace. Followed this to a 4 pin connector which led me
to the battery. PROBLEM SOLVED!!
Thanks to all who commented and helped me solve this problem.
Roger
clifto
So now you're re-volt-ing, right?
Michael A. Terrell
Roger
Do you have the battery type, or any other informartion in case
somone else looks through the Google Groups archives later on?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
dodger741
It was a Panosonic Lithim Battery BR-2/3A 3V with solder tabs.
Approx .625" Dia x 1.25" Long
Roger
Pierre-François
IS it possible to replace the battery without loosing the calibration
parameters?
Or do you have to recalibrate the scope after the battery replacement?
pf
dodger741
parameters?
My review of the manual indicates that all calibration is done
manually. The battery is only used to store the trace data in
"extended memory" which is accessible by the GPIB interface.
Roger
Pierre-François
Thank you Roger, so it's not like on some others scope like the 2465b where
you loose the calibration parameters when the battery is over...
So I'm less anxious and in a hurry...
pf
