tektronix 577 & 576
F
f6iib
I just bought a tek 576 from a leasing company
works but has focus problem
anyone with maintenance manual around in pdfs ....
best regards
patrick
David C. Partridge
For the 577 (not 576) see: ftp://bama.sbc.edu/downloads/tek/577-177-d1/
Jim Yanik
Not anything similar.577 is based on the 5100 series scope chassis and
display,the older 576 is WAY different.
Perhaps a bad resistor in the focus string?
Andreas Tekman
Hi Patrick,
yout topic is a little misleading because you mention both the 577
*and* 576.
Do as Jim recommended. Check the HV area and the focus restor chain of
your 576.
The 577 diagram (or very similar in the HV area: 5100 scope diagram)
might be helpful to get a genral impression how Tektronix curve tracers
are set up in this area around the CRT.
Fotr the 577: David's hint is valuable.
hth,
Andreas
carneyke
Patrick,
The focus is a compromise of the focus and astigmatism setting. Tweek
Jim Yanik
Patrick,
and if the CRT is getting weak,it will naturally defocus;the beam is
emitted from a larger area of the cathode.
